이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Flip the laptop over with the screen facing down to reveal the bottom panel.
Unscrew each of the highlighted screws with a Phillips #0 screwdriver.
Use a metal spudger to remove fitting and reveal the screw.
Use a screwdriver with a Torx T7 bit to remove the screw.
The SD Card slot is on the top right corner of the device near the headphone jacks.
Depress the fake SD Card and release.
Pull the fake SD Card out and remove it completely from the slot, as this will help in the removal of the backplate.
Lift the back plate starting at the opposing edge to the SD card. Lift from left to right and continue lifting this plate at this angle until it's free from the laptop.
Once the backplate is completely off, this will reveal the inside components of the device.
Remove six 5mm screws holding down the battery using a Phillips PH0 screwdriver.
Lift the battery and separate from its place holder.
Using the nylon spudger, disconnect the white plugin.
Once the wire has been disconnected you may remove the battery.
There are two black speakers on either side of the bottom corner of the device.
Remove tape securing speaker wires to frame.
Using a blue plastic opening tool, disconnect the white cable running from the trackpad to the motherboard, at themotherboard port.
The speakers are connected by a plug with wires (Red/Black) (Black/White) to the motherboard.
Simply remove the plug with your fingers, disconnecting the speakers from the motherboard.
With the plug disconnected, now you can remove the speakers.
Lift the speakers up vertically removing them from pegs that hold them in place.
