주요 콘텐츠로 건너뛰기
Porter Cable 690LR Base Latch Replacement
필요한 것
  1. Porter Cable 690LR Base Latch Replacement, Base: 1 단계, 이미지 1/2 Porter Cable 690LR Base Latch Replacement, Base: 1 단계, 이미지 2/2
    • Undo the black latch located on the base of the router by pulling upwards from underneath it.
  2. Porter Cable 690LR Base Latch Replacement: 2 단계, 이미지 1/2 Porter Cable 690LR Base Latch Replacement: 2 단계, 이미지 2/2
    • Twist the base off the router.
    • You may need to jiggle the base of the router slightly.
  3. Porter Cable 690LR Base Latch Replacement, Base Latch: 3 단계, 이미지 1/2 Porter Cable 690LR Base Latch Replacement, Base Latch: 3 단계, 이미지 2/2
    • Locate the 30 mm bolt and nut attaching the latch to the base.
    • Use a wrench to remove the nut attached to the bolt, freeing the latch from the base.
결론
Jaymes Ullrich
회원 가입일: 10/05/16
343 평판
안내서 3개 작성하였습니다
Cal Poly, Team 20-7, Livingston Fall 2016 Cal Poly, Team 20-7, Livingston Fall 2016 회원
CPSU-LIVINGSTON-F16S20G7
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 5
전체 시간: 259
