소개
The replacement process for this part is very simple. It will only take a few minutes, and you can continue with your day.
필요한 것
Locate the 30 mm bolt and nut attaching the latch to the base.
Use a wrench to remove the nut attached to the bolt, freeing the latch from the base.
거의 끝나갑니다!
결론
