주요 콘텐츠로 건너뛰기
Porter Cable 690LR Power Switch Replacement
필요한 것
  1. Porter Cable 690LR Power Switch Replacement, Power Switch: 1 단계, 이미지 1/2 Porter Cable 690LR Power Switch Replacement, Power Switch: 1 단계, 이미지 2/2
    • Use a Torx screwdriver to unscrew the 25.4 mm screws found at the top of the model.
  2. Porter Cable 690LR Power Switch Replacement: 2 단계, 이미지 1/2 Porter Cable 690LR Power Switch Replacement: 2 단계, 이미지 2/2
    • Remove the top by gently lifting the cover from router body.
    • Be careful when pulling the top from its place; wires connect the switch to the electrical cord and could be pulled loose or damaged.
  3. Porter Cable 690LR Power Switch Replacement: 3 단계, 이미지 1/1
    • Use a spudger to pull off the plastic covering of the power switch.
    • Don’t be afraid to really pry underneath the plastic (no components of the router will be damaged if you do so).
  4. Porter Cable 690LR Power Switch Replacement: 4 단계, 이미지 1/1
    • Push the power switch through the top of the router. The power switch should now be completely detached from the router (besides the wire connections).
  5. Porter Cable 690LR Power Switch Replacement: 5 단계, 이미지 1/2 Porter Cable 690LR Power Switch Replacement: 5 단계, 이미지 2/2
    • Find the wire plugs which are attached to the power switch. These connections are located at the back of the plastic box that houses the switch.
    • Use the spudger to carefully loosen the metal and rubber coverings, and detach the connections from the switch.
    • While some force is needed in order to successfully pull the connections free, have care in making sure that you don’t damage any of the metal components. If needed you may carefully use a metal spudger instead of a plastic opening tool.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Jaymes Ullrich
회원 가입일: 10/05/16
343 평판
안내서 3개 작성하였습니다
Cal Poly, Team 20-7, Livingston Fall 2016 Cal Poly, Team 20-7, Livingston Fall 2016 회원
CPSU-LIVINGSTON-F16S20G7
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 15
전체 시간: 901
