주요 콘텐츠로 건너뛰기
Porter-Cable 382 Fan Replacement
필요한 것
  1. Porter-Cable 382 Fan Replacement, Sander Pad: 1 단계, 이미지 1/1
    • When changing the sander pad, be sure to rotate the sander upside down so the pad and three highlighted screws are facing upward toward you.
    • Once the sander is upside down begin by removing your old sandpaper.
    • Once the sandpaper is removed locate the three screws on your sander pad.
  2. Porter-Cable 382 Fan Replacement: 2 단계, 이미지 1/1
    • Remove the three, (star bolt) screws with the iFixit screw driver with a "T20" head. Be sure to hold the pad of the sander as it will rotate as you try to loosen the screws.
    • Once the screws are removed pull upward toward you and the sander pad will come apart from the device.
  3. Porter-Cable 382 Fan Replacement, Dust Seal/ Break: 3 단계, 이미지 1/1
    • Once the sander pad is removed and the sander is exposed locate the white plastic like circular piece surrounding the outside of the sander.
  4. Porter-Cable 382 Fan Replacement: 4 단계, 이미지 1/2 Porter-Cable 382 Fan Replacement: 4 단계, 이미지 2/2
    • Once you have located the plastic white ring pull up its outer edge as shown. The lip on the inside will bend and be freed from its secured placement.
    • To reassemble, you will have to line up the protruding square with the key slot as shown otherwise your dust seal/ brake will not go back in.
  5. Porter-Cable 382 Fan Replacement, Fan: 5 단계, 이미지 1/2 Porter-Cable 382 Fan Replacement, Fan: 5 단계, 이미지 2/2
    • Once the dust brake/ seal is removed locate the screw in the center of the device holding down the bearing and fan assembly.
    • unscrew this bolt using a T20 star bit and carefully remove the washer and bearing as shown.
  6. Porter-Cable 382 Fan Replacement: 6 단계, 이미지 1/1
    • Next locate the bolts holding down the guard assembly as shown. There will be one bolt on each side, two in total.
    • Using a T15 star bit unscrew these bolts and make sure you keep them in a safe place.
  7. Porter-Cable 382 Fan Replacement: 7 단계, 이미지 1/1
    • Once the two screws are removed locate the o-ring that seals the dust collector to its opening.
    • Very delicately pry the o-ring out of its slot using a nylon spudger or plastic opening tool. Then roll it off of the opening as shown.
  8. Porter-Cable 382 Fan Replacement: 8 단계, 이미지 1/2 Porter-Cable 382 Fan Replacement: 8 단계, 이미지 2/2
    • Now the two guards will come apart as shown, giving you access to the fan.
    • During reassembly, the two guards will line up so that the dust collector opening lines up with the power cord as shown.
  9. Porter-Cable 382 Fan Replacement: 9 단계, 이미지 1/1
    • The fan can then simply be pulled from its axle and be replaced with the fan blades facing up.
결론
Nick O'Sadcia
회원 가입일: 03/11/16
421 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team 8-7, Botvin Spring 2016 UMass Dartmouth, Team 8-7, Botvin Spring 2016 회원
UMASSD-BOTVIN-S16S8G7
3 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 5
전체 시간: 338
