주요 콘텐츠로 건너뛰기
Porter-Cable 382 On/ Off Switch Replacement
필요한 것
  1. Porter-Cable 382 On/ Off Switch Replacement, On/ Off Switch: 1 단계, 이미지 1/2 Porter-Cable 382 On/ Off Switch Replacement, On/ Off Switch: 1 단계, 이미지 2/2
    • First, locate the three screws on the top of the sander.
    • Using a screw driver with a size T20 star bit, unscrew the screws by turning them to the left.
  2. Porter-Cable 382 On/ Off Switch Replacement: 2 단계, 이미지 1/2 Porter-Cable 382 On/ Off Switch Replacement: 2 단계, 이미지 2/2
    • Locate your on off switch and in order to remove it you must slide it out of its slot.
    • This shouldnt require any special tools, just wiggle the switch up and out.
    • Make sure this is done carefully, the switch is attached to two wires that may break if they are pulled on too hard.
  3. Porter-Cable 382 On/ Off Switch Replacement: 3 단계, 이미지 1/1
    • Using a spudger such as the one shown, carefully pry open the connectors as shown just enough to slide the prongs of the switch out.
    • Once both prongs are open, the on-off switch can be removed freely and replaced with a new switch.
결론
Nick O'Sadcia
회원 가입일: 03/11/16
421 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team 8-7, Botvin Spring 2016 UMass Dartmouth, Team 8-7, Botvin Spring 2016 회원
UMASSD-BOTVIN-S16S8G7
3 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 7
전체 시간: 230
