주요 콘텐츠로 건너뛰기
Porter-Cable 382 Sander Pad Replacement
필요한 것
  1. Porter-Cable 382 Sander Pad Replacement, Sander Pad: 1 단계, 이미지 1/1
    • When changing the sander pad, be sure to rotate the sander upside down so the pad and three highlighted screws are facing upward toward you.
    • Once the sander is upside down begin by removing your old sandpaper.
    • Once the sandpaper is removed locate the three screws on your sander pad.
  2. Porter-Cable 382 Sander Pad Replacement: 2 단계, 이미지 1/1
    • Remove the three, (star bolt) screws with the iFixit screw driver with a "T20" head. Be sure to hold the pad of the sander as it will rotate as you try to loosen the screws.
    • Once the screws are removed pull upward toward you and the sander pad will come apart from the device.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Nick O'Sadcia
회원 가입일: 03/11/16
421 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team 8-7, Botvin Spring 2016 UMass Dartmouth, Team 8-7, Botvin Spring 2016 회원
UMASSD-BOTVIN-S16S8G7
3 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 17
전체 시간: 1,816
