메인 콘텐츠로 스킵하기
소개
The motor brushes of the Porter-Cable PC60TAG provide a conducting path to the motor, and they may eventually wear down as the device begins to age. Use this guide to replace the brushes of your Porter-Cable PC60TAG.
  1. Using the Phillips #2 screwdriver, remove the 3/4" screw on the back cover.
    • Using the Phillips #2 screwdriver, remove the 3/4" screw on the back cover.
    • Unplug the grinder before disassembling.
  2. Holding the front of the device, carefully slide the back cover over the cord.
    • Holding the front of the device, carefully slide the back cover over the cord.
  3. Using the Phillips #2 screwdriver, remove the 1/2" screw holding on the motor brush arm.
    • Using the Phillips #2 screwdriver, remove the 1/2" screw holding on the motor brush arm.
  4. 맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
    맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
  5. Carefully pull the motor brush arm away from the other device.
    • Carefully pull the motor brush arm away from the other device.
  6. Using the spudger, carefully lift the spring on the motor brush arm off of the motor brush and gently pull it to the side of the motor bush arm.
    • Using the spudger, carefully lift the spring on the motor brush arm off of the motor brush and gently pull it to the side of the motor bush arm.
    • Be careful not to over bend the spring, as this could damage the spring and require replacement.
  7. Using the spudger, gently push the motor brush out of the arm. Using the spudger, gently push the motor brush out of the arm.
    • Using the spudger, gently push the motor brush out of the arm.
  8. Using a pair of needle nose pliers, gently pull the motor brush terminal off of the motor brush arm.
    • Using a pair of needle nose pliers, gently pull the motor brush terminal off of the motor brush arm.
    • Repeat steps 3-7 on the other side of the device.
결론
Mackenzie Fairbanks
회원 가입일: 2016년 03월 24일
528 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team 2-2, Isaacson Spring 2016 UMass Dartmouth, Team 2-2, Isaacson Spring 2016 회원
UMASSD-ISAACSON-S16S2G2
3 회원들
안내서 5개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 13
전체 시간: 269
