주요 콘텐츠로 건너뛰기
Porter-Cable PC60TAG Power Cord Replacement
필요한 것
  1. Porter-Cable PC60TAG Power Cord Replacement, Power Cord: 1 단계, 이미지 1/1
    • Using the Phillips #2 screwdriver, remove the 3/4" Phillips head screw on the back cover.
    • Unplug the grinder before disassembling.
  2. Porter-Cable PC60TAG Power Cord Replacement: 2 단계, 이미지 1/1
    • Holding the front of the device, carefully slide the back cover over the cord.
  3. Porter-Cable PC60TAG Power Cord Replacement: 3 단계, 이미지 1/1
    • Using the Phillips #2 screwdriver, remove the two 1/2" Phillips head screws securing the cord grip.
  4. Porter-Cable PC60TAG Power Cord Replacement: 4 단계, 이미지 1/1
    • Using the Phillips #2 screwdriver, loosen, but do not remove, the two terminal screws securing the black and white wires from the power cord.
  5. Porter-Cable PC60TAG Power Cord Replacement: 5 단계, 이미지 1/1
    • Careful remove each wire from the power cord from underneath the terminals.
결론
Mackenzie Fairbanks
회원 가입일: 03/24/16
564 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team 2-2, Isaacson Spring 2016 UMass Dartmouth, Team 2-2, Isaacson Spring 2016 회원
UMASSD-ISAACSON-S16S2G2
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 433
