주요 콘텐츠로 건너뛰기
Poukaran ZRW-TD-SRK2 LED Replacement
필요한 것
  1. Poukaran ZRW-TD-SRK2 LED Replacement, LED Strip: 1 단계, 이미지 3개 중 1개 Poukaran ZRW-TD-SRK2 LED Replacement, LED Strip: 1 단계, 이미지 3개 중 2개 Poukaran ZRW-TD-SRK2 LED Replacement, LED Strip: 1 단계, 이미지 3개 중 3개
    • Use a Phillips #1 screwdriver to remove the 7.5mm screws securing the front of the lamp's outer casing or lid.
  2. Poukaran ZRW-TD-SRK2 LED Replacement: 2 단계, 이미지 3개 중 1개 Poukaran ZRW-TD-SRK2 LED Replacement: 2 단계, 이미지 3개 중 2개 Poukaran ZRW-TD-SRK2 LED Replacement: 2 단계, 이미지 3개 중 3개
    • Use a Phillips #1 screwdriver to remove the last two 7.5 mm screws securing the back of the lamp's outer casing or lid.
  3. Poukaran ZRW-TD-SRK2 LED Replacement: 3 단계, 이미지 2개 중 1개 Poukaran ZRW-TD-SRK2 LED Replacement: 3 단계, 이미지 2개 중 2개
    • Once the lid is off, locate and remove the top plate covering the internal components of the lamp.
  4. Poukaran ZRW-TD-SRK2 LED Replacement: 4 단계, 이미지 3개 중 1개 Poukaran ZRW-TD-SRK2 LED Replacement: 4 단계, 이미지 3개 중 2개 Poukaran ZRW-TD-SRK2 LED Replacement: 4 단계, 이미지 3개 중 3개
    • Use a soldering iron to carefully desolder the wires connecting the faulty LED strips. Ensure you're desoldering the correct connections. Solder the new LED strips in place, connecting the wires securely to the designated points on the lamp's circuit board.
    • Exercise caution when lifting the plate that holds the LEDs, as there is a risk of accidentally pulling out the wires.
결론
To reassemble your device, follow these instructions in reverse order. Ensure each component is securely in place and all connections are properly aligned.
작성자
1다른 기여자 명과 함께
andrez oceguera
회원 가입일: 08/23/23
109 평판
안내서 1개를 작성함
CSU Los Angeles, Team 2-1, Briggs Fall 2023 CSU Los Angeles, Team 2-1, Briggs Fall 2023 회원
CSULA-BRIGGS-F23S2G1
5 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 26
전체 시간: 274
