소개
Follow this guide to remove the power cord on a EDCO Disk Grinder model 50200-HD.
This is a prerequisite-only guide! This guide is part of another procedure and is not meant to be used alone.
필요한 것
Ensure the machine is unplugged.
Turn the power switch counterclockwise into the OFF position.
Use a Phillips screwdriver to remove the screw securing the red on/off lever.
Use a Phillips screwdriver to remove the four screws securing the upper half of the switch housing to the lower half.
Use a 3/8 inch socket to remove the bolt securing the power cord loom clamp to the switch bracket.
