주요 콘텐츠로 건너뛰기
Power Mac G4 Cube Airport Card Replacement
  1. Power Mac G4 Cube Airport Card Replacement, Remove Cube Core: 1 단계, 이미지 1/3 Power Mac G4 Cube Airport Card Replacement, Remove Cube Core: 1 단계, 이미지 2/3 Power Mac G4 Cube Airport Card Replacement, Remove Cube Core: 1 단계, 이미지 3/3
    • Release the handle at the bottom of the Power Mac G4 Cube by pushing it down. Slowly pull out the cube by holding the end of the handle.
    • Watch for any parts that may become entangled with the outer case.
    • Push back the handle after you have taken the core out of the case.
  2. Power Mac G4 Cube Airport Card Replacement, Accessing AirPort Card: 2 단계, 이미지 1/2 Power Mac G4 Cube Airport Card Replacement, Accessing AirPort Card: 2 단계, 이미지 2/2
    • Pull outwards on the antenna cable.
    • The cable should pop out of the card without much force.
    • Pull on the clear tab outwards to remove the existing AirPort card
    • Slide in the new AirPort card.
    • Reconnect the antenna cable.
결론
다른 8명이 해당 안내서를 완성하였습니다.
Ryan Chun
회원 가입일: 06/24/10
1,076 평판
안내서 7개 작성하였습니다
Cal Poly, Team 2-7, Johann Summer 2010 Cal Poly, Team 2-7, Johann Summer 2010 회원
CPSU-JOHANN-R10S2G7
5 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 9
30일 전: 24
전체 시간: 9,849
