주요 콘텐츠로 건너뛰기
Power Mac G4 Cube Modem Replacement
필요한 것
  1. Power Mac G4 Cube Modem Replacement, Outer Case: 1 단계, 이미지 1/3 Power Mac G4 Cube Modem Replacement, Outer Case: 1 단계, 이미지 2/3 Power Mac G4 Cube Modem Replacement, Outer Case: 1 단계, 이미지 3/3
    • Release the back handle of the PowerMac. Slowly pull out the cube by holding the end of the handle. Watch for any parts that may become entangled with the outer case.
    • Push back the handle after you have taken the core out of the case.
  2. Power Mac G4 Cube Modem Replacement: 2 단계, 이미지 1/2 Power Mac G4 Cube Modem Replacement: 2 단계, 이미지 2/2
    • Place the cube upside down and remove the four T10 Torx screws on the front plate. Then remove the two screws on each side.
  3. Power Mac G4 Cube Modem Replacement: 3 단계, 이미지 1/1
    • Slowly lift the plate off the cube and disconnect the power cord.
  4. Power Mac G4 Cube Modem Replacement: 4 단계, 이미지 1/1
    • Remove the four pillars from each corner.
    • The pillars should come out fairly easily.
  5. Power Mac G4 Cube Modem Replacement, Video Card: 5 단계, 이미지 1/1
    • Remove the screws on the back of the VGA port.
  6. Power Mac G4 Cube Modem Replacement: 6 단계, 이미지 1/1
    • Remove the screw attaching the video card to the logic board.
  7. Power Mac G4 Cube Modem Replacement: 7 단계, 이미지 1/2 Power Mac G4 Cube Modem Replacement: 7 단계, 이미지 2/2
    • Remove power cord from the video card.
  8. Power Mac G4 Cube Modem Replacement: 8 단계, 이미지 1/1
    • Remove the power cord.
    • Remove the connector.
    • Remove the video card from the logic board.
  9. Power Mac G4 Cube Modem Replacement: 9 단계, 이미지 1/1
    • Carefully lift the video card from the logic board.
    • The video card should come out easily.
  10. Power Mac G4 Cube Modem Replacement: 10 단계, 이미지 1/2 Power Mac G4 Cube Modem Replacement: 10 단계, 이미지 2/2
    • Separate the video card from the adapter.
  11. Power Mac G4 Cube Modem Replacement, Modem: 11 단계, 이미지 1/1
    • Remove the two screws from the modem.
  12. Power Mac G4 Cube Modem Replacement: 12 단계, 이미지 1/1
    • Lift modem from the Logic Board.
    • The modem should come out easily.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Ryan Chun
회원 가입일: 06/24/10
1,076 평판
안내서 7개 작성하였습니다
Cal Poly, Team 2-7, Johann Summer 2010 Cal Poly, Team 2-7, Johann Summer 2010 회원
CPSU-JOHANN-R10S2G7
5 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 6
전체 시간: 4,127
