주요 콘텐츠로 건너뛰기
Power Mac G4 M5183 Hard Drive Replacement
필요한 것
  1. Power Mac G4 M5183 Hard Drive Replacement, Opening PowerMac G4 M5183 Case: 1 단계, 이미지 1/2 Power Mac G4 M5183 Hard Drive Replacement, Opening PowerMac G4 M5183 Case: 1 단계, 이미지 2/2
    • Pull on outer latch.
    • Lower door until it is level with your work surface.
    • Before working on the computer make sure it is not plugged into a power supply, then touch a metal object. This discharges static electricity, which could damage the computer.
  2. Power Mac G4 M5183 Hard Drive Replacement, Hard Drive: 2 단계, 이미지 1/2 Power Mac G4 M5183 Hard Drive Replacement, Hard Drive: 2 단계, 이미지 2/2
    • Remove the ribbon cable and power cable from the Hard Drive.
  3. Power Mac G4 M5183 Hard Drive Replacement: 3 단계, 이미지 1/1
    • Remove the screw which holds the Hard Drive tray in place.
  4. Power Mac G4 M5183 Hard Drive Replacement: 4 단계, 이미지 1/1
    • Slide the Hard Drive tray out of the computer.
  5. Power Mac G4 M5183 Hard Drive Replacement: 5 단계, 이미지 1/1
    • To remove the Hard Drive from the tray, unscrew the 4 screws on the bottom of the tray.
결승점
다른 35명이 해당 안내서를 완성하였습니다.
Justin Petrilli
회원 가입일: 01/21/10
3,096 평판
안내서 11개 작성하였습니다
Cal Poly, Team 13-24, Maness Winter 2010 Cal Poly, Team 13-24, Maness Winter 2010 회원
CPSU-MANESS-W10S13G24
4 회원들
안내서 25개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 27
30일 전: 119
전체 시간: 26,234
