주요 콘텐츠로 건너뛰기
Power Mac G4 M5183 Heat Sink Replacement
필요한 것
  1. Power Mac G4 M5183 Heat Sink Replacement, Opening PowerMac G4 M5183 Case: 1 단계, 이미지 1/2 Power Mac G4 M5183 Heat Sink Replacement, Opening PowerMac G4 M5183 Case: 1 단계, 이미지 2/2
    • Pull on outer latch.
    • Lower door until it is level with your work surface.
    • Before working on the computer make sure it is not plugged into a power supply, then touch a metal object. This discharges static electricity, which could damage the computer.
  2. Power Mac G4 M5183 Heat Sink Replacement, Heat Sink: 2 단계, 이미지 1/2 Power Mac G4 M5183 Heat Sink Replacement, Heat Sink: 2 단계, 이미지 2/2
    • Use the spudger to pry the clips horizontally off of the heat sink.
    • Fully remove the clips by lifting upwards.
  3. Power Mac G4 M5183 Heat Sink Replacement: 3 단계, 이미지 1/1
    • Remove the heat sink by pulling upwards, off of the logic board.
결승점
다른 6명이 해당 안내서를 완성하였습니다.
Justin Petrilli
회원 가입일: 01/21/10
3,114 평판
안내서 11개 작성하였습니다
Cal Poly, Team 13-24, Maness Winter 2010 Cal Poly, Team 13-24, Maness Winter 2010 회원
CPSU-MANESS-W10S13G24
4 회원들
안내서 25개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 5
전체 시간: 5,832
