소개
Replacing the internal battery which regulates several functions in the computer, including the calendar.
Pull on outer latch.
Lower door until it is level with your work surface.
Locate the battery.
Remove and replace battery.
Push the PMU button once, and only once, to reset the power supply.
다른 19명이 해당 안내서를 완성하였습니다.
댓글 3개
Nice simple post. You might make the battery number / size more obvious, for anxious nerds like me…
Thank you!
Not bad, but PMU button location is not explained… the button on the front to start it?
rwwseditor - 답글
Hi
Will a 3V Lithium battery work or must it be 3.6V?
Please advise.
Rgds
Duard
