주요 콘텐츠로 건너뛰기
Power Mac G4 M5183 Logic Board Replacement
필요한 것
  1. Power Mac G4 M5183 Logic Board Replacement, Opening PowerMac G4 M5183 Case: 1 단계, 이미지 1/2 Power Mac G4 M5183 Logic Board Replacement, Opening PowerMac G4 M5183 Case: 1 단계, 이미지 2/2
    • Pull on outer latch.
    • Lower door until it is level with your work surface.
    • Before working on the computer make sure it is not plugged into a power supply, then touch a metal object. This discharges static electricity, which could damage the computer.
    Fino a li lo intuisce anche un bambino. Io volevo sapere come levare l'altro sportello senza rompere niente. Ma una vodtra risposta non la vedo.
    giorgus - 답글
  2. Power Mac G4 M5183 Logic Board Replacement, Heat Sink: 2 단계, 이미지 1/2 Power Mac G4 M5183 Logic Board Replacement, Heat Sink: 2 단계, 이미지 2/2
    • Use the spudger to pry the clips horizontally off of the heat sink.
    • Fully remove the clips by lifting upwards.
  3. Power Mac G4 M5183 Logic Board Replacement: 3 단계, 이미지 1/1
    • Remove the heat sink by pulling upwards, off of the logic board.
  4. Power Mac G4 M5183 Logic Board Replacement, RAM: 4 단계, 이미지 1/2 Power Mac G4 M5183 Logic Board Replacement, RAM: 4 단계, 이미지 2/2
    • Locate the RAM modules.
    • Pull side tabs outward. The RAM will pop out of the housing.
  5. Power Mac G4 M5183 Logic Board Replacement, Graphics Card: 5 단계, 이미지 1/2 Power Mac G4 M5183 Logic Board Replacement, Graphics Card: 5 단계, 이미지 2/2
    • Remove the single screw with the Phillips #1 screwdriver.
    • Pull the graphics card up and out.
  6. Power Mac G4 M5183 Logic Board Replacement, Logic Board: 6 단계, 이미지 1/2 Power Mac G4 M5183 Logic Board Replacement, Logic Board: 6 단계, 이미지 2/2
    • Remove the six indicated cables attached to the logic board.
    • Use the spudger to remove the modem cable as indicated.
  7. Power Mac G4 M5183 Logic Board Replacement: 7 단계, 이미지 1/2 Power Mac G4 M5183 Logic Board Replacement: 7 단계, 이미지 2/2
    • Unfasten 3 Phillips screws revealed beneath the heat sink on the CPU board.
    • Carefully remove the CPU board from the Mother Board.
    • Remove the barrell nut screws from the Mother Board which held the CPU board.
    • Unfasten 3 Phillips #1 screws on Mother Board as shown in illustration 1.
    • Slide the logic board about a quarter of an inch to free it from the three retaining pins.
    • Pull upwards and outwards to fully remove the logic board.
  8. Power Mac G4 M5183 Logic Board Replacement: 8 단계, 이미지 1/1
    • After removing the (3) #2 philips screws, remove the (4) 1/4" hex nuts, then slide as directed and remove board.
결승점
다른 15명이 해당 안내서를 완성하였습니다.
Justin Petrilli
회원 가입일: 01/21/10
3,114 평판
안내서 11개 작성하였습니다
Cal Poly, Team 13-24, Maness Winter 2010 Cal Poly, Team 13-24, Maness Winter 2010 회원
CPSU-MANESS-W10S13G24
4 회원들
안내서 25개 작성하였습니다
댓글 3개
Are the "hex nuts" under the processor board? Could you provide a close up picture of the "nuts?"
D george - 답글
So what is being replaced here? Wouldn’t one have to purchase a new logic board? Any info would be greatly appreciated!
Sandra Cai - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 12
30일 전: 56
전체 시간: 17,929
