소개
This guide details the removal of the main fan from the fan housing.
부품
지정된 부품이 없습니다.
Pull on outer latch.
Lower door until it is level with your work surface.
Remove the screw from each of the two niches on lower part of fan using the Phillips #1 screwdriver.
To fully remove the fan, unfasten the 4 screws on the front of the bracing using the Phillips #2 screwdriver.
거의 끝나갑니다!
결론
다른 3명이 해당 안내서를 완성하였습니다.
