소개
How to remove the processor from the logic board.
필요한 것
Pull on outer latch.
Lower door until it is level with your work surface.
Use the spudger to pry the clips horizontally off of the heat sink.
Fully remove the clips by lifting upwards.
Remove the 3 screws attaching the processor to the logic board using the Phillips #2 screwdriver.
Remove processor by pulling vertically upwards.
다른 13명이 해당 안내서를 완성하였습니다.
댓글 2개
anyone still sell the replacement processor?
Anyone who has upgraded their CPU’s manage to flash from MacPro1,1 to MacPro2,1? And If so How?
Fino a li lo intuisce anche un bambino. Io volevo sapere come levare l'altro sportello senza rompere niente. Ma una vodtra risposta non la vedo.
giorgus - 답글
