주요 콘텐츠로 건너뛰기
Power Mac G4 MDD AirPort Card Replacement
필요한 것
  1. Power Mac G4 MDD AirPort Card Replacement, Case: 1 단계, 이미지 2개 중 1개 Power Mac G4 MDD AirPort Card Replacement, Case: 1 단계, 이미지 2개 중 2개
    • The Power Mac G4 MDD: the last, and the fastest G4-based Mac. This computer boasted up to a Dual 1.42GHz PowerPC G4 CPU (though I have a single 1.25GHz).
    • Two USB 1.1 Ports
    • Assorted Audio
    • Video (ADC & DVI)
    • Networking (RJ-45 Ethernet/56k Modem)
    • Some later model MDD's (such as the dual 1.42GHz) Have a FireWire 800 Port Here:
  2. Power Mac G4 MDD AirPort Card Replacement: 2 단계, 이미지 3개 중 1개 Power Mac G4 MDD AirPort Card Replacement: 2 단계, 이미지 3개 중 2개 Power Mac G4 MDD AirPort Card Replacement: 2 단계, 이미지 3개 중 3개
    • Unplug the computer.
    • Unplug the power supply and all external connections from the computer.
    • Pull on the side lever and lower the side of the case.
  3. Power Mac G4 MDD AirPort Card Replacement, AirPort Card: 3 단계, 이미지 3개 중 1개 Power Mac G4 MDD AirPort Card Replacement, AirPort Card: 3 단계, 이미지 3개 중 2개 Power Mac G4 MDD AirPort Card Replacement, AirPort Card: 3 단계, 이미지 3개 중 3개
    • The AirPort card is located next to the graphics card.
    • If your computer has a FireWire 800 port between the FireWire 400 Ports and the Ethernet Ports then your computer uses an AirPort Extreme 802.11g Card (See Related Parts). If your computer has no firewire 800 port, then your computer uses an 802.11b AirPort PCMCIA Card (Also See Related Parts). Removal of both cards is pretty much the same.
    • First disconnect the antenna from the card, it may be helpful to use a spudger or flathead screwdriver.
    • Now, grasp the plastic tab on the back of the card and pull it out of the computer.
  4. Power Mac G4 MDD AirPort Card Replacement: 4 단계, 이미지 1개 중 1개
    • The Airport 802.11b PCMCIA Card.
결론
다른 13명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Chris Green
회원 가입일: 10/11/09
38,086 평판
안내서 49개를 작성함
Master Techs Master Techs 회원
Community
329 회원들
안내서 1,451개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 10
지난 30일: 39
전체 시간: 29,323
