주요 콘텐츠로 건너뛰기
Power Mac G4 MDD CPU Heatsink Replacement
필요한 것
  1. Power Mac G4 MDD CPU Heatsink Replacement, Case: 1 단계, 이미지 2개 중 1개 Power Mac G4 MDD CPU Heatsink Replacement, Case: 1 단계, 이미지 2개 중 2개
    • The Power Mac G4 MDD: the last, and the fastest G4-based Mac. This computer boasted up to a Dual 1.42GHz PowerPC G4 CPU (though I have a single 1.25GHz).
    • Two USB 1.1 Ports
    • Assorted Audio
    • Video (ADC & DVI)
    • Networking (RJ-45 Ethernet/56k Modem)
    • Some later model MDD's (such as the dual 1.42GHz) Have a FireWire 800 Port Here:
  2. Power Mac G4 MDD CPU Heatsink Replacement: 2 단계, 이미지 3개 중 1개 Power Mac G4 MDD CPU Heatsink Replacement: 2 단계, 이미지 3개 중 2개 Power Mac G4 MDD CPU Heatsink Replacement: 2 단계, 이미지 3개 중 3개
    • Unplug the computer.
    • Unplug the power supply and all external connections from the computer.
    • Pull on the side lever and lower the side of the case.
  3. Power Mac G4 MDD CPU Heatsink Replacement, RAM: 3 단계, 이미지 3개 중 1개 Power Mac G4 MDD CPU Heatsink Replacement, RAM: 3 단계, 이미지 3개 중 2개 Power Mac G4 MDD CPU Heatsink Replacement, RAM: 3 단계, 이미지 3개 중 3개
    • The ram is between the graphics card, and the CPU, and removal is simple. Push the tabs down on both sides, this will free the ram, then lift it out.
    • The MDD uses a maximum of 2GB PC2700 DDR RAM (512MB X4) and has 4 slots.
  4. Power Mac G4 MDD CPU Heatsink Replacement, CPU Heatsink: 4 단계, 이미지 1개 중 1개
    • Now, remove these three Phillips screws:
    • As there are two Phillips screws well, there are two that you can see in the photo, but you want to remove the screws that are behind them.
  5. Power Mac G4 MDD CPU Heatsink Replacement: 5 단계, 이미지 2개 중 1개 Power Mac G4 MDD CPU Heatsink Replacement: 5 단계, 이미지 2개 중 2개
    • Now, lift the heatsink up off the computer, it is pretty heavy, because it's a giant block of aluminum.
    • Be careful when holding it, the edges can be sharp, making it likely to get cut if you hold it wrong!
    • As you may be able to tell, i have applied a replacement coat of Arctic Silver 5 to keep my MDD cooler than the stock paste, it really does a great job too!
  6. Power Mac G4 MDD CPU Heatsink Replacement: 6 단계, 이미지 2개 중 1개 Power Mac G4 MDD CPU Heatsink Replacement: 6 단계, 이미지 2개 중 2개
    • The incredibly large heatsink, this thing is 5 Lbs of solid aluminum. Just like every other part in this, and many other Macs, the heatsink is made by: ...you guessed it, Foxconn.
    • Before reinstalling, ensure that you clean the old thermal paste off of the heatsink with alcohol.
결론
다른 9명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Chris Green
회원 가입일: 10/11/09
38,086 평판
안내서 49개를 작성함
Master Techs Master Techs 회원
Community
329 회원들
안내서 1,451개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 16
지난 30일: 45
전체 시간: 20,353
