주요 콘텐츠로 건너뛰기
Power Mac G4 Quicksilver Logic Board Replacement
필요한 것
  1. Power Mac G4 Quicksilver Logic Board Replacement, Opening the case: 1 단계, 이미지 1개 중 1개
    • The handle to open your computer is located on top of the right side panel.
  2. Power Mac G4 Quicksilver Logic Board Replacement: 2 단계, 이미지 2개 중 1개 Power Mac G4 Quicksilver Logic Board Replacement: 2 단계, 이미지 2개 중 2개
    • Grab the circular handle and pull outward.
  3. Power Mac G4 Quicksilver Logic Board Replacement: 3 단계, 이미지 1개 중 1개
    • Your computer is now open and ready for repair.
  4. Power Mac G4 Quicksilver Logic Board Replacement, Video Adapter: 4 단계, 이미지 1개 중 1개
    • This is your Power Mac G4's video adapter.
  5. Power Mac G4 Quicksilver Logic Board Replacement: 5 단계, 이미지 1개 중 1개
    • Start by removing the screw holding the card to the chassis as shown.
  6. Power Mac G4 Quicksilver Logic Board Replacement: 6 단계, 이미지 1개 중 1개
    • Before lifting the card out, this small plastic tab needs to be pulled back there by releasing it entirely.
  7. Power Mac G4 Quicksilver Logic Board Replacement: 7 단계, 이미지 2개 중 1개 Power Mac G4 Quicksilver Logic Board Replacement: 7 단계, 이미지 2개 중 2개
    • With the tab and screw removed, lift the card straight out.
    • When putting the card back in, take care to apply even pressure across the top with your thumbs. This will avoid damaging the card.
  8. Power Mac G4 Quicksilver Logic Board Replacement, Logic Board: 8 단계, 이미지 1개 중 1개
    • Disconnect both the power cables and IDE cable from the mother board.
  9. Power Mac G4 Quicksilver Logic Board Replacement: 9 단계, 이미지 1개 중 1개
    • Remove these three screws that hold the motherboard fan and modem connector to the chassis.
  10. Power Mac G4 Quicksilver Logic Board Replacement: 10 단계, 이미지 1개 중 1개
    • Remove the four screws shown to free the mother board from the chassis.
  11. Power Mac G4 Quicksilver Logic Board Replacement: 11 단계, 이미지 3개 중 1개 Power Mac G4 Quicksilver Logic Board Replacement: 11 단계, 이미지 3개 중 2개 Power Mac G4 Quicksilver Logic Board Replacement: 11 단계, 이미지 3개 중 3개
    • Lift the fan shroud and fan straight up and out. Take care to disconnect the indicated connector
    • Remove the heatsink clamps with a flathead screwdriver and do the same for the other side.
    • Lift off the heatsink and remove the 4 screws of the CPU board.
    • There are 4 pins: remove the 3 pins near the RAM but not the pin nearest You.
    • You are now ready to slide gently (and without ANY difficult) the motherboard. Lift up and the game is done.
결론
다른 10명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Cameron Christensen
회원 가입일: 01/20/10
590 평판
안내서 3개를 작성함
Cal Poly, Team 14-41, Regan Winter 2010 Cal Poly, Team 14-41, Regan Winter 2010 회원
CPSU-REGAN-W10S14G41
4 회원들
안내서 27개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 19
전체 시간: 17,508
