주요 콘텐츠로 건너뛰기
Power Mac G4 Quicksilver Optical Drive Replacement
필요한 것
  1. Power Mac G4 Quicksilver Optical Drive Replacement, Opening the case: 1 단계, 이미지 1/1
    • The handle to open your computer is located on top of the right side panel.
  2. Power Mac G4 Quicksilver Optical Drive Replacement: 2 단계, 이미지 1/2 Power Mac G4 Quicksilver Optical Drive Replacement: 2 단계, 이미지 2/2
    • Grab the circular handle and pull outward.
  3. Power Mac G4 Quicksilver Optical Drive Replacement: 3 단계, 이미지 1/1
    • Your computer is now open and ready for repair.
  4. Power Mac G4 Quicksilver Optical Drive Replacement, Power Mac G4 Quicksilver Optical Drive Disassembly: 4 단계, 이미지 1/1
    • The optical drive is in the top left corner of the case.
  5. Power Mac G4 Quicksilver Optical Drive Replacement: 5 단계, 이미지 1/2 Power Mac G4 Quicksilver Optical Drive Replacement: 5 단계, 이미지 2/2
    • There are four screws to be removed.
    • The first screw can be seen in the first picture.
    • The remaining three screws can be seen in the second picture.
  6. Power Mac G4 Quicksilver Optical Drive Replacement: 6 단계, 이미지 1/1
    • Remove the optical drive by pulling the drive away from the front of the computer and out.
  7. Power Mac G4 Quicksilver Optical Drive Replacement: 7 단계, 이미지 1/1
    • Detach the two cables attached to the back of the drive.
    • The flat ribbon cable can be detached by pulling the silver tab. The multicolored cable can be removed by grasping the plastic connector on either side and pulling with substantial force.
  8. Power Mac G4 Quicksilver Optical Drive Replacement, Optical Drive: 8 단계, 이미지 1/1
    • Remove the four screws holding the enclosure to the drive.
  9. Power Mac G4 Quicksilver Optical Drive Replacement: 9 단계, 이미지 1/1
    • Push on the back of the drive (side with the connectors) to slide the drive out of the enclosure.
    • Your optical drive is now ready to be replaced.
결론
다른 8명이 해당 안내서를 완성하였습니다.
Ryan Bylard
회원 가입일: 01/20/10
1,325 평판
안내서 5개 작성하였습니다
Cal Poly, Team 14-41, Regan Winter 2010 Cal Poly, Team 14-41, Regan Winter 2010 회원
CPSU-REGAN-W10S14G41
4 회원들
안내서 17개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 18
전체 시간: 11,235
