소개
This guide will show you how to remove and replace the Video Adapter in your Power Mac 4 Quicksilver.
부품
부품은 필요하지 않습니다.
  1. The handle to open your computer is located on top of the right side panel.
    • The handle to open your computer is located on top of the right side panel.
  2. Grab the circular handle and pull outward. Grab the circular handle and pull outward.
    • Grab the circular handle and pull outward.
  3. Your computer is now open and ready for repair.
    • Your computer is now open and ready for repair.
  4. US$100 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
    상점 둘러보기
  5. This is your Power Mac G4's video adapter.
    • This is your Power Mac G4's video adapter.
  6. Start by removing the screw holding the card to the chassis as shown.
    • Start by removing the screw holding the card to the chassis as shown.
  7. Before lifting the card out, this small plastic tab needs to be pulled back there by releasing it entirely.
    • Before lifting the card out, this small plastic tab needs to be pulled back there by releasing it entirely.
  8. With the tab and screw removed, lift the card straight out. When putting the card back in, take care to apply even pressure across the top with your thumbs. This will avoid damaging the card.
    • With the tab and screw removed, lift the card straight out.
    • When putting the card back in, take care to apply even pressure across the top with your thumbs. This will avoid damaging the card.
  9. Your card is now completely removed and ready to be replaced.
    • Your card is now completely removed and ready to be replaced.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Cameron Christensen
회원 가입일: 2010년 01월 20일
549 평판
안내서 3개 작성하였습니다
Cal Poly, Team 14-41, Regan Winter 2010 Cal Poly, Team 14-41, Regan Winter 2010 회원
CPSU-REGAN-W10S14G41
4 회원들
안내서 10개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 5
지난 30일: 6
전체 시간: 6,470
