주요 콘텐츠로 건너뛰기
Power Mac G5 Graphics Card Replacement
필요한 것
  1. Power Mac G5 Graphics Card Replacement, Side Panel: 1 단계, 이미지 1/1
    • To avoid electrocution, shut down the computer. Do not open the computer or attempt to install any items inside it while the computer is on.
    • To avoid being burned, wait at least 10 minutes to allow the computer's internal components to cool.
  2. Power Mac G5 Graphics Card Replacement: 2 단계, 이미지 1/1
    • Remove all the cables, including the power cables before opening the unit.
  3. Power Mac G5 Graphics Card Replacement: 3 단계, 이미지 1/2 Power Mac G5 Graphics Card Replacement: 3 단계, 이미지 2/2
    • Lift the tab to unlock the side panel.
    • The panel should fall out. If the panel does not fall out by itself pull a little from the edges.
  4. Power Mac G5 Graphics Card Replacement: 4 단계, 이미지 1/3 Power Mac G5 Graphics Card Replacement: 4 단계, 이미지 2/3 Power Mac G5 Graphics Card Replacement: 4 단계, 이미지 3/3
    • Remove the air deflector (the clear plastic cover) by pulling on the handle.
  5. Power Mac G5 Graphics Card Replacement, Graphics Card: 5 단계, 이미지 1/1
    • Locate the graphics card in the desktop.
  6. Power Mac G5 Graphics Card Replacement: 6 단계, 이미지 1/2 Power Mac G5 Graphics Card Replacement: 6 단계, 이미지 2/2
    • Using a Phillips # 1 screw driver, unscrew the screw right next to the graphics card.
  7. Power Mac G5 Graphics Card Replacement: 7 단계, 이미지 1/1
    • Last thing to do is to gently shake the card out of it's slot by pulling it straight out. (If the card does not come out easily, don't force it. You need to release a latch on the logic board behind the AGP connector while pulling out the video card.)
결론
다른 37명이 해당 안내서를 완성하였습니다.
Salvador Aguilar
회원 가입일: 01/21/10
2,481 평판
안내서 3개 작성하였습니다
Cal Poly, Team 5-8, Forte Winter 2010 Cal Poly, Team 5-8, Forte Winter 2010 회원
CPSU-FORTE-W10S5G8
7 회원들
안내서 20개 작성하였습니다
댓글 5개
hello, i’m wondering what’s the maxi ram of graphic card can be accepted by g5? we know it can do 128m 256m in standard, but what if we install a 512m or even 1go ram graphic card, it there anyone who has tried please? thank you!
qian daniel - 답글
Hi Salvador,
Many thanks for the guide. I already knew all the steps until the ‘secret’ release mechanism, which is why I came to this page.
So, it would be really handy for future viewers if you included a picture of the position and design of the release latch. It would have saved me from fumbling around for 15 minutes pressing an unrelated button, which is situated just behind the release latch.
Anthony Lythgoe - 답글
I agree. The most important step for this to be helpful, the release mechanism, is not shown at all.
Anton Uhl -
I agree too, maybe we could add a picture?
Hamish McIntyre-Bhatty -
What are some compatible graphics cards to replace the one that's in the Mac by default? I tried taking it out and giving it time to rest. Then plugged it back in and it still doesn't work when I use a monitor on it. Any suggestions?
Yahia Milton - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 25
30일 전: 95
전체 시간: 42,129
