주요 콘텐츠로 건너뛰기
Power Mac G5 Top Left Cooling Fan Unit Replacement
  1. Power Mac G5 Top Left Cooling Fan Unit Replacement, Side Panel: 1 단계, 이미지 1/1
    • To avoid electrocution, shut down the computer. Do not open the computer or attempt to install any items inside it while the computer is on.
    • To avoid being burned, wait at least 10 minutes to allow the computer's internal components to cool.
  2. Power Mac G5 Top Left Cooling Fan Unit Replacement: 2 단계, 이미지 1/1
    • Remove all the cables, including the power cables before opening the unit.
  3. Power Mac G5 Top Left Cooling Fan Unit Replacement: 3 단계, 이미지 1/2 Power Mac G5 Top Left Cooling Fan Unit Replacement: 3 단계, 이미지 2/2
    • Lift the tab to unlock the side panel.
    • The panel should fall out. If the panel does not fall out by itself pull a little from the edges.
  4. Power Mac G5 Top Left Cooling Fan Unit Replacement: 4 단계, 이미지 1/3 Power Mac G5 Top Left Cooling Fan Unit Replacement: 4 단계, 이미지 2/3 Power Mac G5 Top Left Cooling Fan Unit Replacement: 4 단계, 이미지 3/3
    • Remove the air deflector (the clear plastic cover) by pulling on the handle.
  5. Power Mac G5 Top Left Cooling Fan Unit Replacement, Top Left Cooling Fan Unit: 5 단계, 이미지 1/1
    • Locate the top left cooling fan unit.
  6. Power Mac G5 Top Left Cooling Fan Unit Replacement: 6 단계, 이미지 1/1
    • Pull the fan straight out from its slot. You will need to remove two cables from the motherboard.
    • It may be easier to reach the cables if you remove the PCI guide (next to the fan unit) first.
  7. Power Mac G5 Top Left Cooling Fan Unit Replacement: 7 단계, 이미지 1/1
    • After pulling out the fan unit, the area should look like this.
결론
다른 20명이 해당 안내서를 완성하였습니다.
Salvador Aguilar
회원 가입일: 01/21/10
2,481 평판
안내서 3개 작성하였습니다
Cal Poly, Team 5-8, Forte Winter 2010 Cal Poly, Team 5-8, Forte Winter 2010 회원
CPSU-FORTE-W10S5G8
7 회원들
안내서 20개 작성하였습니다
댓글 한 개
Actually you do need to remove the plastic air deflector, as the fan in question is behind it.
Tim downing - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 12
전체 시간: 19,090
