주요 콘텐츠로 건너뛰기
Power Macintosh G3 (Minitower) Chassis Locking Latch Replacement
필요한 것
    • Press the green release button on top of the side access panel.
    • Pull off the side access panel to get inside the computer.
    • When putting the side access panel back on, make sure that the bottom of the panel lines up with the rail on the bottom, and that the chassis is locked with the green latches.
    • Using a Phillips screwdriver, unscrew the latch screw and remove it, along with the washer.
    • Remove the locking latch.
    • Repeat this step for the other latch.
결론
작성자
2다른 기여자 명과 함께
LeoI07
회원 가입일: 06/10/21
1,573 평판
안내서 17개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 6
지난 30일: 17
전체 시간: 224
