주요 콘텐츠로 건너뛰기
Power Macintosh G3 Blue and White Graphics Card Replacement
필요한 것
  1. Power Macintosh G3 Blue and White Graphics Card Replacement, Graphics Card: 1 단계, 이미지 1/1
    • Unfortunately, I am unable to provide OG content for this step due to my PowerMac’s outer case being severely damaged. Once I get my new outer case I will update this step.
    • Lift the latch on the right side panel to reveal the internals.
    • If you are doing this on a hard surface I highly suggest you put a mat down between the door and the ground to prevent scratches.
  2. Power Macintosh G3 Blue and White Graphics Card Replacement: 2 단계, 이미지 1/2 Power Macintosh G3 Blue and White Graphics Card Replacement: 2 단계, 이미지 2/2
    • Remove the single Phillips #1 screw circled in the picture. Set it aside for later.
    • The graphics card is outlined in red in the second image, if you are confused on where this is.
  3. Power Macintosh G3 Blue and White Graphics Card Replacement: 3 단계, 이미지 1/1
    • Lift the graphics card straight out of it's PCI slot.
    • Be careful not to lift sideways, you can damage the PCI slot! Try your best to lift the graphics card straight up.
결론
다른 2명이 해당 안내서를 완성하였습니다.
[deleted]
회원 가입일: 08/28/18
26,409 평판
안내서 21개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 9
30일 전: 35
전체 시간: 1,562
