주요 콘텐츠로 건너뛰기
Power Macintosh G3 Blue and White Graphics Card Replacement
필요한 것
  1. Power Macintosh G3 Blue and White Graphics Card Replacement, Graphics Card: 1 단계, 이미지 1개 중 1개
    • Unfortunately, I am unable to provide OG content for this step due to my PowerMac’s outer case being severely damaged. Once I get my new outer case I will update this step.
    • Lift the latch on the right side panel to reveal the internals.
    • If you are doing this on a hard surface I highly suggest you put a mat down between the door and the ground to prevent scratches.
  2. Power Macintosh G3 Blue and White Graphics Card Replacement: 2 단계, 이미지 2개 중 1개 Power Macintosh G3 Blue and White Graphics Card Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the single Phillips #1 screw circled in the picture. Set it aside for later.
    • The graphics card is outlined in red in the second image, if you are confused on where this is.
  3. Power Macintosh G3 Blue and White Graphics Card Replacement: 3 단계, 이미지 1개 중 1개
    • Lift the graphics card straight out of it's PCI slot.
    • Be careful not to lift sideways, you can damage the PCI slot! Try your best to lift the graphics card straight up.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
[deleted]
회원 가입일: 08/28/18
27,571 평판
안내서 21개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 11
지난 30일: 32
전체 시간: 2,054
