주요 콘텐츠로 건너뛰기
Power Macintosh G3 Blue and White Modem Replacement
필요한 것
  1. Power Macintosh G3 Blue and White Modem Replacement, Before opening up your Power Mac...: 1 단계, 이미지 1개 중 1개
    • Remove the Phillips #1 screw circled in the picture. Set it aside for re-assembly.
  2. Power Macintosh G3 Blue and White Modem Replacement: 2 단계, 이미지 1개 중 1개
    • Unfortunately, I am unable to provide OG content for this step due to my Power Mac’s outer case being severely damaged. Once I get my new outer case I will update this step.
    • Lift the latch on the right side panel to reveal the internals.
    • If you are doing this on a hard surface I highly suggest you put a mat down between the door and the ground to prevent scratches.
  3. Power Macintosh G3 Blue and White Modem Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the single Phillips #1 screw circled in the picture.
    • I apologize for the lack of picture quality. The only camera and lighting I had were my iPhone X´s camera and a table lamp. Lol!
  4. Power Macintosh G3 Blue and White Modem Replacement: 4 단계, 이미지 1개 중 1개
    • Disconnect the modem’s flex cable from the connector on the logic board.
    • Lift the modem assembly out of it´s place on the logic board.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
[deleted]
회원 가입일: 08/28/18
27,571 평판
안내서 21개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 11
전체 시간: 835
