주요 콘텐츠로 건너뛰기
Power Macintosh G3 Blue and White PRAM Battery Replacement
필요한 것
  1. Power Macintosh G3 Blue and White PRAM Battery Replacement, PRAM Battery: 1 단계, 이미지 1/1
    • Unfortunately, I am unable to provide OG content for this step due to my Power Mac’s outer case being severely damaged. Once I get my new outer case I will update this step.
    • Lift the latch on the right side panel to reveal the internals.
    • If you are doing this on a hard surface I highly suggest you put a mat down between the door and the ground to prevent scratches.
  2. Power Macintosh G3 Blue and White PRAM Battery Replacement: 2 단계, 이미지 1/1
    • Locate the PRAM battery.
    • The PRAM battery is usually at the top right corner of the logic board.
  3. Power Macintosh G3 Blue and White PRAM Battery Replacement: 3 단계, 이미지 1/1
    • Lift the battery out of the PRAM battery holder.
    • What I did to free the PRAM battery is I broke the plastic battery holder identical to the circled one on the other side of the PRAM battery, then I was able to free the PRAM battery. I couldn't get the PRAM battery to budge without breaking the holder.
    • Don't be worried, breaking the plastic holder won't cause much damage nor will it hinder the ability for the PRAM battery to stay in place. Only break one holder, though.
결론
다른 2명이 해당 안내서를 완성하였습니다.
[deleted]
회원 가입일: 08/28/18
25,896 평판
안내서 21개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 39
전체 시간: 2,227
