주요 콘텐츠로 건너뛰기
Power Macintosh G3 Blue and White RAM Replacement
필요한 것
  1. Power Macintosh G3 Blue and White RAM Replacement, RAM: 1 단계, 이미지 1개 중 1개
    • Unfortunately, I am unable to provide OG content for this step due to my PowerMac’s outer case being severely damaged. Once I get my new outer case I will update this step.
    • Lift the latch on the right side panel to reveal the internals of the Power Mac.
    • If you are doing this on a hard surface I highly suggest you put a mat down between the door and the ground to prevent scratches.
  2. Power Macintosh G3 Blue and White RAM Replacement: 2 단계, 이미지 1개 중 1개
    • Push the white tabs next to where your RAM is located away form the RAM chip itself.
    • The RAM chips should move up a tad and become somewhat loose.
    • Your RAM configuration may vary. This process is done the exact same way no matter what your RAM placement looks like.
  3. Power Macintosh G3 Blue and White RAM Replacement: 3 단계, 이미지 2개 중 1개 Power Macintosh G3 Blue and White RAM Replacement: 3 단계, 이미지 2개 중 2개
    • Pull the RAM chips out of the RAM slots.
    • That's all folks! That wasn't too hard, was it?
    • Second image: RAM remains
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
[deleted]
회원 가입일: 08/28/18
27,571 평판
안내서 21개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 44
지난 30일: 173
전체 시간: 1,466
