주요 콘텐츠로 건너뛰기
Power Macintosh G3 Minitower I/O Card Replacement
필요한 것
    • Press the green release button on top of the side access panel.
    • Pull off the side access panel to get inside the computer.
    • When putting the side access panel back on, make sure that the bottom of the panel lines up with the rail on the bottom, and that the chassis is locked with the green latches.
    • Lay the computer on its side, ensuring that where the side access panel was is facing up.
    • Unlock the top chassis by moving the two green locking latches upward and outward.
    • Using the handle, gently swing the top chassis up and out until it rests firmly on the work surface.
    • Remove the screw at the back of the computer holding the I/O card in place.
    • Remove the two screws inside the computer securing the I/O card to the metal chassis.
    • Gently lift up the I/O card to remove it from the computer.
결론
작성자
1다른 기여자 명과 함께
LeoI07
회원 가입일: 06/10/21
1,573 평판
안내서 17개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 90
