주요 콘텐츠로 건너뛰기
PowerA Enhanced Wireless Controller L and R Thumbstick Cover Replacement
필요한 것
  1. PowerA Enhanced Wireless Controller L and R Thumbstick Cover Replacement, Motherboard: 1 단계, 이미지 3개 중 1개 PowerA Enhanced Wireless Controller L and R Thumbstick Cover Replacement, Motherboard: 1 단계, 이미지 3개 중 2개 PowerA Enhanced Wireless Controller L and R Thumbstick Cover Replacement, Motherboard: 1 단계, 이미지 3개 중 3개
    • Remove the battery cover by pressing down on the lever located on the top of the cover.
    • Apply pressure until it clicks out of place, and pull it off.
  2. PowerA Enhanced Wireless Controller L and R Thumbstick Cover Replacement: 2 단계, 이미지 1개 중 1개
    • Remove all eight screws using the J0 screwdriver.
  3. PowerA Enhanced Wireless Controller L and R Thumbstick Cover Replacement: 3 단계, 이미지 2개 중 1개 PowerA Enhanced Wireless Controller L and R Thumbstick Cover Replacement: 3 단계, 이미지 2개 중 2개
    • Insert the iFixit opening tool into the seam and gently pry the cover plate up.
    • Remove the cover plate once it is loosened.
  4. PowerA Enhanced Wireless Controller L and R Thumbstick Cover Replacement: 4 단계, 이미지 3개 중 1개 PowerA Enhanced Wireless Controller L and R Thumbstick Cover Replacement: 4 단계, 이미지 3개 중 2개 PowerA Enhanced Wireless Controller L and R Thumbstick Cover Replacement: 4 단계, 이미지 3개 중 3개
    • Remove all three screws securing the motherboard using the J00 screwdriver.
    • Remove the motherboard.
  5. PowerA Enhanced Wireless Controller L and R Thumbstick Cover Replacement, L and R Thumbsticks Covers: 5 단계, 이미지 3개 중 1개 PowerA Enhanced Wireless Controller L and R Thumbstick Cover Replacement, L and R Thumbsticks Covers: 5 단계, 이미지 3개 중 2개 PowerA Enhanced Wireless Controller L and R Thumbstick Cover Replacement, L and R Thumbsticks Covers: 5 단계, 이미지 3개 중 3개
    • Pull the L and R stick covers out of the socket.
결론
다른 13명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Ayjah Montgomery
회원 가입일: 10/10/19
420 평판
안내서 4개를 작성함
USF Tampa, Team S1-G5, Leahy Fall 2019 USF Tampa, Team S1-G5, Leahy Fall 2019 회원
USFT-LEAHY-F19S1G5
3 회원들
안내서 11개를 작성함
21가이드 댓글
My controllers are drifting, What can i do after getting the joystick of to fix that.
MilesGDC - 답글
i dont know i cleaned using plush sticks ( that usually go to ears that one ) i used that and isopropacol alcohoc 90%
it works for 2 weeks ( on me ) and now my Right analog stick is too Loose to wiggle there
BrunoS -
Where can I get replacement thumbsticks for this controller? Are they the same as the Switch Pro Controllers?
engelgott0972 - 답글
i need replacement joy-sticks too
BrunoS -
I need a link for the thumbsticks too. Cant seem to find them anywhere and PowerA does no sell them nor is willing to help.
Brandon Kohl -
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 39
지난 30일: 204
전체 시간: 16,095
