주요 콘텐츠로 건너뛰기
PowerA Enhanced Wireless Controller L and R Thumbstick Replacement
필요한 것
  1. PowerA Enhanced Wireless Controller L and R Thumbstick Replacement, Motherboard: 1 단계, 이미지 1/3 PowerA Enhanced Wireless Controller L and R Thumbstick Replacement, Motherboard: 1 단계, 이미지 2/3 PowerA Enhanced Wireless Controller L and R Thumbstick Replacement, Motherboard: 1 단계, 이미지 3/3
    • Remove the battery cover by pressing down on the lever located on the top of the cover.
    • Apply pressure until it clicks out of place, and pull it off.
  2. PowerA Enhanced Wireless Controller L and R Thumbstick Replacement: 2 단계, 이미지 1/1
    • Remove all eight screws using the J0 screwdriver.
  3. PowerA Enhanced Wireless Controller L and R Thumbstick Replacement: 3 단계, 이미지 1/2 PowerA Enhanced Wireless Controller L and R Thumbstick Replacement: 3 단계, 이미지 2/2
    • Insert the iFixit opening tool into the seam and gently pry the cover plate up.
    • Remove the cover plate once it is loosened.
  4. PowerA Enhanced Wireless Controller L and R Thumbstick Replacement: 4 단계, 이미지 1/3 PowerA Enhanced Wireless Controller L and R Thumbstick Replacement: 4 단계, 이미지 2/3 PowerA Enhanced Wireless Controller L and R Thumbstick Replacement: 4 단계, 이미지 3/3
    • Remove all three screws securing the motherboard using the J00 screwdriver.
    • Remove the motherboard.
  5. PowerA Enhanced Wireless Controller L and R Thumbstick Replacement, L and R Thumbsticks: 5 단계, 이미지 1/3 PowerA Enhanced Wireless Controller L and R Thumbstick Replacement, L and R Thumbsticks: 5 단계, 이미지 2/3 PowerA Enhanced Wireless Controller L and R Thumbstick Replacement, L and R Thumbsticks: 5 단계, 이미지 3/3
    • Pull the L and R sticks out of the socket.
결론
다른 11명이 해당 안내서를 완성하였습니다.
Ayjah Montgomery
회원 가입일: 10/10/19
402 평판
안내서 4개 작성하였습니다
USF Tampa, Team S1-G5, Leahy Fall 2019 USF Tampa, Team S1-G5, Leahy Fall 2019 회원
USFT-LEAHY-F19S1G5
3 회원들
안내서 10개 작성하였습니다
댓글 19개
My controllers are drifting, What can i do after getting the joystick of to fix that.
MilesGDC - 답글
i dont know i cleaned using plush sticks ( that usually go to ears that one ) i used that and isopropacol alcohoc 90%
it works for 2 weeks ( on me ) and now my Right analog stick is too Loose to wiggle there
BrunoS -
Where can I get replacement thumbsticks for this controller? Are they the same as the Switch Pro Controllers?
engelgott0972 - 답글
i need replacement joy-sticks too
BrunoS -
I need a link for the thumbsticks too. Cant seem to find them anywhere and PowerA does no sell them nor is willing to help.
Brandon Kohl -
댓글 쓰기
조회 통계:
24 시간 전: 10
7일 전: 43
30일 전: 165
전체 시간: 12,996
