주요 콘텐츠로 건너뛰기
PowerA Enhanced Wireless Controller L and R buttons Replacement
필요한 것
  1. PowerA Enhanced Wireless Controller L and R buttons Replacement, Motherboard: 1 단계, 이미지 3개 중 1개 PowerA Enhanced Wireless Controller L and R buttons Replacement, Motherboard: 1 단계, 이미지 3개 중 2개 PowerA Enhanced Wireless Controller L and R buttons Replacement, Motherboard: 1 단계, 이미지 3개 중 3개
    • Remove the battery cover by pressing down on the lever located on the top of the cover.
    • Apply pressure until it clicks out of place, and pull it off.
  2. PowerA Enhanced Wireless Controller L and R buttons Replacement: 2 단계, 이미지 1개 중 1개
    • Remove all eight screws using the J0 screwdriver.
  3. PowerA Enhanced Wireless Controller L and R buttons Replacement: 3 단계, 이미지 2개 중 1개 PowerA Enhanced Wireless Controller L and R buttons Replacement: 3 단계, 이미지 2개 중 2개
    • Insert the iFixit opening tool into the seam and gently pry the cover plate up.
    • Remove the cover plate once it is loosened.
  4. PowerA Enhanced Wireless Controller L and R buttons Replacement: 4 단계, 이미지 3개 중 1개 PowerA Enhanced Wireless Controller L and R buttons Replacement: 4 단계, 이미지 3개 중 2개 PowerA Enhanced Wireless Controller L and R buttons Replacement: 4 단계, 이미지 3개 중 3개
    • Remove all three screws securing the motherboard using the J00 screwdriver.
    • Remove the motherboard.
  5. PowerA Enhanced Wireless Controller L and R buttons Replacement, L and R buttons: 5 단계, 이미지 3개 중 1개 PowerA Enhanced Wireless Controller L and R buttons Replacement, L and R buttons: 5 단계, 이미지 3개 중 2개 PowerA Enhanced Wireless Controller L and R buttons Replacement, L and R buttons: 5 단계, 이미지 3개 중 3개
    • Lift the two white latches using the iFixit opening tool.
    • Lift the white covering off.
  6. PowerA Enhanced Wireless Controller L and R buttons Replacement: 6 단계, 이미지 3개 중 1개 PowerA Enhanced Wireless Controller L and R buttons Replacement: 6 단계, 이미지 3개 중 2개 PowerA Enhanced Wireless Controller L and R buttons Replacement: 6 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Squeeze the buttons with rubber tweezers and push them in.
    • Grab it from the back and pull it out.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Ayjah Montgomery
회원 가입일: 10/10/19
420 평판
안내서 4개를 작성함
USF Tampa, Team S1-G5, Leahy Fall 2019 USF Tampa, Team S1-G5, Leahy Fall 2019 회원
USFT-LEAHY-F19S1G5
3 회원들
안내서 11개를 작성함
2가이드 댓글
I need to know how to fix the ZR and the ZL buttons, like a faster response time
Starry Milligan - 답글
im sure this would be really helpful if i knew where i could buy the parts?
arch1e b - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 16
지난 30일: 52
전체 시간: 4,050
