주요 콘텐츠로 건너뛰기
PowerA Fusion Controller For Xbox One Buttons Replacement
필요한 것
  1. PowerA Fusion Controller For Xbox One Buttons Replacement, Buttons: 1 단계, 이미지 1/3 PowerA Fusion Controller For Xbox One Buttons Replacement, Buttons: 1 단계, 이미지 2/3 PowerA Fusion Controller For Xbox One Buttons Replacement, Buttons: 1 단계, 이미지 3/3
    • Remove the (9) nine 9.2mm screws with a JIS #1 screwdriver.
    • Remove the two bottom plastic grip covers.
  2. PowerA Fusion Controller For Xbox One Buttons Replacement: 2 단계, 이미지 1/2 PowerA Fusion Controller For Xbox One Buttons Replacement: 2 단계, 이미지 2/2
    • Remove the (2) two 9.2mm screws with a JIS #1 screwdriver.
    • Remove the back cover of the controller.
  3. PowerA Fusion Controller For Xbox One Buttons Replacement: 3 단계, 이미지 1/3 PowerA Fusion Controller For Xbox One Buttons Replacement: 3 단계, 이미지 2/3 PowerA Fusion Controller For Xbox One Buttons Replacement: 3 단계, 이미지 3/3
    • Remove the (5) five 9.2mm screws with a JIS #1 screwdriver.
    • Lift the motherboard and let it hang.
  4. PowerA Fusion Controller For Xbox One Buttons Replacement: 4 단계, 이미지 1/2 PowerA Fusion Controller For Xbox One Buttons Replacement: 4 단계, 이미지 2/2
    • Remove the (4) four 9.2mm screws that are holding the motherboard to the controller.
    • Put the motherboard aside.
  5. PowerA Fusion Controller For Xbox One Buttons Replacement: 5 단계, 이미지 1/2 PowerA Fusion Controller For Xbox One Buttons Replacement: 5 단계, 이미지 2/2
    • Remove the buttons.
  6. PowerA Fusion Controller For Xbox One Buttons Replacement: 6 단계, 이미지 1/2 PowerA Fusion Controller For Xbox One Buttons Replacement: 6 단계, 이미지 2/2
    • Go back to the motherboard, and remove the buttons' gasket with a tweezler.
결론
다른 8명이 해당 안내서를 완성하였습니다.
Andrea
회원 가입일: 09/26/17
623 평판
안내서 4개 작성하였습니다
USF Tampa, Team S14-G4, Boczar Fall 2017 USF Tampa, Team S14-G4, Boczar Fall 2017 회원
USFT-BOCZAR-F17S14G4
4 회원들
안내서 5개 작성하였습니다
댓글 2개
Okay so what do you do if by any chance one of the links that are sawdered to the mother board for the D Pad Connection cable breaks… Then what? How would I go about fixing that????
Heather Jesse - 답글
is there a guide to clean the bumpers out? my RB became less consistent and i'm hoping it's just because they're gunked up
urmum - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 12
30일 전: 77
전체 시간: 18,421
