주요 콘텐츠로 건너뛰기
PowerBeats3 Wireless Headphones by Dr. Dre Battery Replacement
필요한 것
  1. PowerBeats3 Wireless Headphones by Dr. Dre Battery Replacement, Locate Battery Side: 1 단계, 이미지 1/2 PowerBeats3 Wireless Headphones by Dr. Dre Battery Replacement, Locate Battery Side: 1 단계, 이미지 2/2
    • Battery is located in the right side headphone housing.
  2. PowerBeats3 Wireless Headphones by Dr. Dre Battery Replacement, Heat Battery Housing: 2 단계, 이미지 1/1
    • Use a heat gun with temperature set to 140 F for about 2-3 minutes and heat the casing where it attaches together as seen in the picture.
  3. PowerBeats3 Wireless Headphones by Dr. Dre Battery Replacement, Remove Housing: 3 단계, 이미지 1/3 PowerBeats3 Wireless Headphones by Dr. Dre Battery Replacement, Remove Housing: 3 단계, 이미지 2/3 PowerBeats3 Wireless Headphones by Dr. Dre Battery Replacement, Remove Housing: 3 단계, 이미지 3/3
    • After heating for about 2-3 minutes, separate the housing using a pry tool as seen in the pictures.
  4. PowerBeats3 Wireless Headphones by Dr. Dre Battery Replacement, Remove/Replace Battery: 4 단계, 이미지 1/1
    • Use a soldering iron to desolder battery connection to remove battery and replace with new one.
결론
다른 13명이 해당 안내서를 완성하였습니다.
Faizan Naveed
회원 가입일: 04/12/17
3,294 평판
안내서 8개 작성하였습니다
Mobile Device Repair Factory Mobile Device Repair Factory 회원
Business
1 회원
안내서 16개 작성하였습니다
댓글 5개
If you need this part you can order it here
https://www.joesge.com/products/powerbea...
JoesGE - 답글
My battery only was connected by two wires. Is that a newer edition of the Powerbeats than this one? Has Apple changed their wiring?
Andrew Manwaring - 답글
Where can I get the batteries? Is it available besides beats showroom?
Tara Chandrabura - 답글
My bettry is too good work but tha wireis want to b change
Asoo Malik - 답글
Plzz tel me how I can change tha wire of my power beats
Asoo Malik - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 24
30일 전: 118
전체 시간: 29,061
