주요 콘텐츠로 건너뛰기
PowerBook 180 Modem Replacement
필요한 것
  1. PowerBook 180 Modem Replacement, Modem: 1 단계, 이미지 1/2 PowerBook 180 Modem Replacement, Modem: 1 단계, 이미지 2/2
    • Remove the Ni-Cad battery from the PowerBook 180.
    • Slide the arrows toward the front of the computer until the battery can slide out.
  2. PowerBook 180 Modem Replacement: 2 단계, 이미지 1/2 PowerBook 180 Modem Replacement: 2 단계, 이미지 2/2
    • Removing the screws securing the bottom plate from the PowerBook 180.
    • There are 5 Torx T8 screws, 4 of which are located on the bottom and 1 on the back above the modem port.
  3. PowerBook 180 Modem Replacement: 3 단계, 이미지 1/2 PowerBook 180 Modem Replacement: 3 단계, 이미지 2/2
    • Your computer should look like the two pictures after the bottom plate is removed.
  4. PowerBook 180 Modem Replacement: 4 단계, 이미지 1/2 PowerBook 180 Modem Replacement: 4 단계, 이미지 2/2
    • Locate the modem board, which is next to the DC-in port.
    • There are two Torx T8 screws marked in red in the pictures. Remove these screws and pull up on the modem board to remove.
    • To reassemble your PowerBook, follow these instructions in reverse.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Jack Byrnes
회원 가입일: 10/17/10
1,244 평판
안내서 2개 작성하였습니다
Master Techs Master Techs 회원
Community
322 회원들
안내서 2,521개 작성하였습니다
댓글 한 개
Great guide. Worked for me of the Powerbook 140. Thanks!
Jack - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 6
전체 시간: 1,610
