주요 콘텐츠로 건너뛰기
PowerBook 180 Ram Replacement
필요한 것
  1. PowerBook 180 Ram Replacement, Ram: 1 단계, 이미지 2개 중 1개 PowerBook 180 Ram Replacement, Ram: 1 단계, 이미지 2개 중 2개
    • The PowerBook 180 has a removable Ni-Cad battery on the side. Before we start this repair, we need to make sure the computer does not have any power source - so you don't get shocked and the computer doesn't die.
    • Slide the battery door to the front of the computer, as directed by the arrows.
    • Pull out the battery.
  2. PowerBook 180 Ram Replacement: 2 단계, 이미지 2개 중 1개 PowerBook 180 Ram Replacement: 2 단계, 이미지 2개 중 2개
    • There are 5 Torx T8 screws that hold the bottom of the PowerBook 180.
    • 4 are on the side, and one is above the modem port at the back of the computer.
    • Remove these screws.
  3. PowerBook 180 Ram Replacement: 3 단계, 이미지 2개 중 1개 PowerBook 180 Ram Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the bottom plate by prying up with either a flathead screwdriver or plastic object, such as a credit card.
    • Keep in mind the bottom left and right corners of the PowerBook 180 is very hard to open - you may need to use some extra force to open that side.
    • Your PowerBook 180 should look like the two pictures - with separate top and bottom halves.
  4. PowerBook 180 Ram Replacement: 4 단계, 이미지 1개 중 1개
    • Identify the RAM in the PowerBook 180. It is marked in red in the picture.
    • For this PowerBook, there is 4mb of Kingston RAM - a lot back in those times!
  5. PowerBook 180 Ram Replacement: 5 단계, 이미지 2개 중 1개 PowerBook 180 Ram Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the RAM by using a plastic object (such as a credit card) along the red marked area in the picture. The RAM is very flexible, so be very careful.
    • Now place the new RAM into the empty socket.
    • Follow these instructions in reverse order to reassemble the PowerBook 180.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Jack Byrnes
회원 가입일: 10/17/10
1,244 평판
안내서 2개를 작성함
Master Techs Master Techs 회원
Community
329 회원들
안내서 1,453개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 14
전체 시간: 3,611
