이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
Before performing any maintenance or repairs ensure that the PowerBook is unplugged and the battery has been removed.
Close the screen and turn the PowerBook over. Orient the computer so the text of the label is right side up.
To reassemble your device, simply slide the battery back into the slot until it snaps into place.
다른 4명이 해당 안내서를 완성하였습니다.
댓글 한 개
hey, I was wandering how do i replace the PRAM battery. If you know how i will apriciatte if you post a guide of how to do it. thanks
TOBI Pugli - 답글
