소개
If your hard drive was damaged or you want to upgrade it you will need to remove the old hard drive first. However, the hard drive is one of the hardest components to reach. Make sure you are able to keep all removed parts organized to make your reassembly process easier.
필요한 것
Close the screen and turn the PowerBook over, orienting the computer upside down, using the label to guide you.
With a Torx T8 screwdriver, remove the three Torx 24mm screws along the center of the back panel.
Push the display screen back to give yourself enough space to remove the side panels.
Remove the panels on either side by gently but firmly pulling up on them with both hands.
Remove the three T8 10mm long torx screws along the bottom of the casing next to the hard drive.
Install the new hard drive by following these instructions in reverse order.
다른 6명이 해당 안내서를 완성하였습니다.
