주요 콘텐츠로 건너뛰기
PowerBook 3400 M3553 Hard Drive Replacement
필요한 것
  1. PowerBook 3400 M3553 Hard Drive Replacement, Battery: 1 단계, 이미지 1/1
    • Close the screen and turn the PowerBook over, orienting the computer upside down, using the label to guide you.
  2. PowerBook 3400 M3553 Hard Drive Replacement: 2 단계, 이미지 1/2 PowerBook 3400 M3553 Hard Drive Replacement: 2 단계, 이미지 2/2
    • Hold the button on the front left side and slide the battery out.
  3. PowerBook 3400 M3553 Hard Drive Replacement, Keyboard: 3 단계, 이미지 1/1
    • With a Torx T8 screwdriver, remove the three Torx 24mm screws along the center of the back panel.
  4. PowerBook 3400 M3553 Hard Drive Replacement: 4 단계, 이미지 1/3 PowerBook 3400 M3553 Hard Drive Replacement: 4 단계, 이미지 2/3 PowerBook 3400 M3553 Hard Drive Replacement: 4 단계, 이미지 3/3
    • Turn the computer over and open the display. You should see that the keyboard is loose.
    • Before attempting to remove the keyboard, note that a ribbon cable connects the keyboard to the logic board. Improper removal may damage your keyboard.
    • Slightly lift the front of the keyboard up, and slide the keyboard towards yourself.
    • Carefully lift the top half of the keyboard and pull it towards yourself.
  5. PowerBook 3400 M3553 Hard Drive Replacement: 5 단계, 이미지 1/2 PowerBook 3400 M3553 Hard Drive Replacement: 5 단계, 이미지 2/2
    • Loosen the ribbon cables connecting the keyboard to the computer by using a plastic opening tool to lift the tabs on either side of the cable port.
    • Gently remove the ribbons from its tabs.
    I did find that, strictly speaking, you don’t need to remove the ribbons. If you carefully hold up the keyboard up towards the screen with one hand, you can remove the old RAM and install the new one with the other. I suppose you could also use a length of masking tape to hold the keyboard up.
    I found it easier not to remove the ribbon, especially as I couldn’t find my plastic opening tool.
    Scott - 답글
  6. PowerBook 3400 M3553 Hard Drive Replacement, RAM: 6 단계, 이미지 1/2 PowerBook 3400 M3553 Hard Drive Replacement, RAM: 6 단계, 이미지 2/2
    • Gently wiggle the RAM card to loosen the connection until it pulls free.
  7. PowerBook 3400 M3553 Hard Drive Replacement, Speaker Panel: 7 단계, 이미지 1/2 PowerBook 3400 M3553 Hard Drive Replacement, Speaker Panel: 7 단계, 이미지 2/2
    • Disconnect the wires from the port.
    Speaker panel? I don’t think this is correct - I accidently pulled the black & red wires out from this part and sound still worked fine. Is this instead a battery connection?
    Matt - 답글
    thats correct, that red/black wire comes from the green Varta battery under the speaker panel. This PRAM battery most of the time has gone bad since the 90s and it's electrolyte fluid dropped down onto the main board, destroying other parts.
    Jamba - 답글
  8. PowerBook 3400 M3553 Hard Drive Replacement: 8 단계, 이미지 1/1
    • Remove the 7mm screw connecting the speaker panel to the computer.
  9. PowerBook 3400 M3553 Hard Drive Replacement: 9 단계, 이미지 1/2 PowerBook 3400 M3553 Hard Drive Replacement: 9 단계, 이미지 2/2
    • To detach the speaker panel's ribbon cable, use a plastic opening tool to lift the tabs on both sides of the cable port.
    • Once loose, pull the ribbon cable free.
  10. PowerBook 3400 M3553 Hard Drive Replacement: 10 단계, 이미지 1/2 PowerBook 3400 M3553 Hard Drive Replacement: 10 단계, 이미지 2/2
    • Lift the lighting/audio panel from it's bottom corners and pull the panel towards yourself.
  11. PowerBook 3400 M3553 Hard Drive Replacement, Track Pad Panel: 11 단계, 이미지 1/1
    • Push the display screen back to give yourself enough space to remove the side panels.
    • Before removing the side panels, note that removing the side panels hastily will damage the underlying panel screw. However, this will not affect the functionality of your PowerBook.
    • Remove the panels on either side by gently but firmly pulling up on them with both hands.
  12. PowerBook 3400 M3553 Hard Drive Replacement: 12 단계, 이미지 1/2 PowerBook 3400 M3553 Hard Drive Replacement: 12 단계, 이미지 2/2
    • Use the plastic opening tool to lift up the tabs on either side of the ribbon cable port and then gently pull the ribbon cable free.
  13. PowerBook 3400 M3553 Hard Drive Replacement: 13 단계, 이미지 1/3 PowerBook 3400 M3553 Hard Drive Replacement: 13 단계, 이미지 2/3 PowerBook 3400 M3553 Hard Drive Replacement: 13 단계, 이미지 3/3
    • WARNING: There is a high risk of breaking the tabs that lock the panel to the casing. Remove the panel slowly and cautiously to avoid damage.
    • With your index finger and your thumb, squeeze the track pad panel to loosen the clamps. Then slide the panel towards yourself.
  14. PowerBook 3400 M3553 Hard Drive Replacement, Hard Drive: 14 단계, 이미지 1/2 PowerBook 3400 M3553 Hard Drive Replacement, Hard Drive: 14 단계, 이미지 2/2
    • Remove the three T8 10mm long torx screws along the bottom of the casing next to the hard drive.
  15. PowerBook 3400 M3553 Hard Drive Replacement: 15 단계, 이미지 1/1
    • A ribbon cable is attached to the underside of the hard drive. Hasty removal of the hard drive can damage the ribbon cable.
    • Gently lift up on the hard drive.
  16. PowerBook 3400 M3553 Hard Drive Replacement: 16 단계, 이미지 1/2 PowerBook 3400 M3553 Hard Drive Replacement: 16 단계, 이미지 2/2
    • Rotate the hard drive towards yourself to access the ribbon cable and then gently pull up on the ribbon cable connector to remove the cable.
    • You might find it easier to set the hard drive on its side while disconnect the ribbon cable.
  17. PowerBook 3400 M3553 Hard Drive Replacement: 17 단계, 이미지 1/1
    • Place the hard drive so that the casing is facing up.
    • Remove the 4 T8 5mm long torx screws to remove the hard drive from the metal casing.
  18. PowerBook 3400 M3553 Hard Drive Replacement: 18 단계, 이미지 1/1
    • Lift the metal casing off of the hard drive.
  19. PowerBook 3400 M3553 Hard Drive Replacement: 19 단계, 이미지 1/1
    • Remove and set aside the black protector that was under the hard drive casing.
  20. PowerBook 3400 M3553 Hard Drive Replacement: 20 단계, 이미지 1/3 PowerBook 3400 M3553 Hard Drive Replacement: 20 단계, 이미지 2/3 PowerBook 3400 M3553 Hard Drive Replacement: 20 단계, 이미지 3/3
    • If your replacement drive did not come with a ribbon cable, use a plastic opening tool to remove the ribbon cable from your old hard drive.
    • Use a plastic opening tool to loosen the ribbon cable by running it along the connection and gently prying it free.
    • When you have loosened the connection, pull the tab to remove the ribbon cable.
결론
Install the new hard drive by following these instructions in reverse order.
다른 6명이 해당 안내서를 완성하였습니다.
Michael Mondragon
회원 가입일: 04/12/11
274 평판
안내서 9개 작성하였습니다
Cal Poly, Team 24-59, Amido Spring 2011 Cal Poly, Team 24-59, Amido Spring 2011 회원
CPSU-AMIDO-S11S24G59
4 회원들
안내서 9개 작성하였습니다
댓글 2개
Thanks for the great guide! I used this guide on my Original PowerBook G3 (Kanga / 3500). Thank you!
Stephen - 답글
Looks like a excellent guide. I have a Kanga waiting and now I will make a plan
dscpinc - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 10
30일 전: 39
전체 시간: 5,876
