주요 콘텐츠로 건너뛰기
PowerBook 3400 M3553 Keyboard Replacement
필요한 것
  1. PowerBook 3400 M3553 Keyboard Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Close the screen and turn the PowerBook over, orienting the computer upside down, using the label to guide you.
  2. PowerBook 3400 M3553 Keyboard Replacement: 2 단계, 이미지 2개 중 1개 PowerBook 3400 M3553 Keyboard Replacement: 2 단계, 이미지 2개 중 2개
    • Hold the button on the front left side and slide the battery out.
  3. PowerBook 3400 M3553 Keyboard Replacement, Keyboard: 3 단계, 이미지 1개 중 1개
    • With a Torx T8 screwdriver, remove the three Torx 24mm screws along the center of the back panel.
  4. PowerBook 3400 M3553 Keyboard Replacement: 4 단계, 이미지 3개 중 1개 PowerBook 3400 M3553 Keyboard Replacement: 4 단계, 이미지 3개 중 2개 PowerBook 3400 M3553 Keyboard Replacement: 4 단계, 이미지 3개 중 3개
    • Turn the computer over and open the display. You should see that the keyboard is loose.
    • Before attempting to remove the keyboard, note that a ribbon cable connects the keyboard to the logic board. Improper removal may damage your keyboard.
    • Slightly lift the front of the keyboard up, and slide the keyboard towards yourself.
    • Carefully lift the top half of the keyboard and pull it towards yourself.
  5. PowerBook 3400 M3553 Keyboard Replacement: 5 단계, 이미지 2개 중 1개 PowerBook 3400 M3553 Keyboard Replacement: 5 단계, 이미지 2개 중 2개
    • Loosen the ribbon cables connecting the keyboard to the computer by using a plastic opening tool to lift the tabs on either side of the cable port.
    • Gently remove the ribbons from its tabs.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
11다른 기여자 명과 함께
Michael Mondragon
회원 가입일: 04/12/11
397 평판
안내서 9개를 작성함
Cal Poly, Team 24-59, Amido Spring 2011 Cal Poly, Team 24-59, Amido Spring 2011 회원
CPSU-AMIDO-S11S24G59
4 회원들
안내서 9개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 13
전체 시간: 2,440
