주요 콘텐츠로 건너뛰기
PowerBook G3 Lombard PRAM Battery Replacement
필요한 것
  1. PowerBook G3 Lombard PRAM Battery Replacement, Keyboard: 1 단계, 이미지 1/1
    • Turn the computer so that the ports are facing you.
    • If the keyboard is locked, open the port cover and turn the keyboard locking screw until the keyboard is unlocked.
  2. PowerBook G3 Lombard PRAM Battery Replacement: 2 단계, 이미지 1/1
    • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
    • Make sure you have removed the laptop battery and CD/DVD module from the expansion bays before proceeding.
  3. PowerBook G3 Lombard PRAM Battery Replacement: 3 단계, 이미지 1/1
    • Lift the keyboard out by pulling it up and away from you. Rest the keyboard, face down, on top of the trackpad.
    • In order to replace the keyboard, you must first remove the modem.
  4. PowerBook G3 Lombard PRAM Battery Replacement, PRAM Battery: 4 단계, 이미지 1/1
    • Pull the battery cable directly up from the logic board.
  5. PowerBook G3 Lombard PRAM Battery Replacement: 5 단계, 이미지 1/1
    • Remove the battery from its holder by pulling up and to the left.
결론
다른 5명이 해당 안내서를 완성하였습니다.
첨부 문서
iRobot
회원 가입일: 09/24/09
1 평판
안내서 636개 작성하였습니다
댓글 2개
Step 4, 5 and 6 are useless for changing the PRAM battery..
Godzil - 답글
Seems the step I was referring to are no longer there!
Godzil -
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 16
30일 전: 28
전체 시간: 10,939
