주요 콘텐츠로 건너뛰기
기기를 고치세요
수리할 권리
부품 & 도구
소개
The power card connects your batteries to the computer.
  1. Turn the computer so that the ports are facing you.
    • Turn the computer so that the ports are facing you.
    • If the keyboard is locked, open the port cover and turn the keyboard locking screw until the keyboard is unlocked.
  2. Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
    • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
    • Make sure you have removed the laptop battery and CD/DVD module from the expansion bays before proceeding.
  3. Lift the keyboard out by pulling it up and away from you. Rest the keyboard, face down, on top of the trackpad.
    • Lift the keyboard out by pulling it up and away from you. Rest the keyboard, face down, on top of the trackpad.
    • In order to replace the keyboard, you must first remove the modem.
  4. Remove the three silver Phillips screws that attach the heat shield to the internal metal framework.
    • Remove the three silver Phillips screws that attach the heat shield to the internal metal framework.
  5. Lift the heat shield up and pull it toward you.
    • Lift the heat shield up and pull it toward you.
  6. Your laptop should look approximately like this.
    • Your laptop should look approximately like this.
  7. Pull the battery cable directly up from the logic board.
    • Pull the battery cable directly up from the logic board.
  8. Remove the battery from its holder by pulling up and to the left.
    • Remove the battery from its holder by pulling up and to the left.
  9. Remove the two silver Phillips screws from the modem.
    • Remove the two silver Phillips screws from the modem.
  10. Use a spudger, the tips of your fingers, or a flat non-metal tool to get under the modem's edge and pry it up from its socket as shown in the picture.
    • Use a spudger, the tips of your fingers, or a flat non-metal tool to get under the modem's edge and pry it up from its socket as shown in the picture.
  11. Disconnect the cable from the right side of the modem.
    • Disconnect the cable from the right side of the modem.
  12. Your laptop should look approximately like this.
  13. Use a spudger, the tips of your fingers, or a flat non-metal tool to pry up the processor's right side.
    • Use a spudger, the tips of your fingers, or a flat non-metal tool to pry up the processor's right side.
  14. Nintendo Switch 키트
    게임으로 돌아가기 위한 빠른 해결책
    Nintendo Switch 키트 쇼핑하기
    Nintendo Switch 키트
    게임으로 돌아가기 위한 빠른 해결책
  15. Disconnect the keyboard cable from the logic board by pulling directly up on the clear plastic loop.
    • Disconnect the keyboard cable from the logic board by pulling directly up on the clear plastic loop.
    • This step is out of sequence with the keyboard because in order to remove the keyboard you must first remove the modem.
  16. Your laptop should look approximately like this.
  17. Release the tabs on each side of the RAM chip at the same time. These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
    • Release the tabs on each side of the RAM chip at the same time. These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
    • Pull the RAM chip out.
    • There are RAM slots on both sides of the processor. We recommend installing higher capacity chips on the bottom so that if you want to upgrade later, you won't have to remove the processor.
  18. Grasp the orange cable at the left end of the hard drive and disconnect it from the logic board.
    • Grasp the orange cable at the left end of the hard drive and disconnect it from the logic board.
    • Try to grasp the cable on the plastic connector rather than on the flexible cable section.
  19. Grasp the plastic tab and pull the hard drive up and to the left, making sure that the metal bracket doesn't catch on the black plastic casing.
    • Grasp the plastic tab and pull the hard drive up and to the left, making sure that the metal bracket doesn't catch on the black plastic casing.
  20. Push the display back so that it lies flat.
    • Push the display back so that it lies flat.
  21. Slip a spudger or your index finger under the clutch cover near the power button and pull gently upward until you feel it come free.
    • Slip a spudger or your index finger under the clutch cover near the power button and pull gently upward until you feel it come free.
    • Repeat the previous step on the left side.
  22. Lift the clutch cover up and off, rotating it toward yourself.
    • Lift the clutch cover up and off, rotating it toward yourself.
  23. Grasp the orange display data cable and disconnect it from the logic board.
    • Grasp the orange display data cable and disconnect it from the logic board.
    • Pull the display cable straight up so that it is vertical.
  24. Grasp the thin display inverter board at its left end, push the left end forward to get the board beyond the tab, and then lift the entire board up.
    • Grasp the thin display inverter board at its left end, push the left end forward to get the board beyond the tab, and then lift the entire board up.
    • There are two tabs that hold the display inverter in place that you need to get past in order to pull the board free.
  25. Disconnect the white inverter cable connector from the right end of the board.
    • Disconnect the white inverter cable connector from the right end of the board.
  26. Disconnect the inverter plug, pulling directly up from the logic board.
    • Disconnect the inverter plug, pulling directly up from the logic board.
  27. Your laptop should look approximately like this.
  28. Turn the laptop around so that its back faces you.
    • Turn the laptop around so that its back faces you.
    • Open the port door located at the back of the laptop.
    • Remove the four black Torx screws.
  29. Hold the display on both sides and pull directly up until its hinges are free of their mounts.
    • Hold the display on both sides and pull directly up until its hinges are free of their mounts.
  30. Your laptop should look approximately like this.
  31. Remove the three long silver and two short black Torx screws from the beige plastic casing.
    • Remove the three long silver and two short black Torx screws from the beige plastic casing.
  32. Turn the Lombard so that the trackpad is nearest you and slide the thin plastic shield away from you, out from under the black casing.
    • Turn the Lombard so that the trackpad is nearest you and slide the thin plastic shield away from you, out from under the black casing.
    • Disconnect the newly revealed thin orange ribbon from the logic board, to the left of the trackpad.
    • Remove the two long silver Torx screws.
    • Turn the laptop over.
    • Remove the seven Torx screws from the bottom casing.
    • There are two long screws in the front left and front right corners; make sure to put these back in the proper place when reassembling.
    • Turn the laptop back over.
    • Remove the three short black Torx screws from the metal frame.
    • Remove the short black Torx screw to the far left that fastens the logic board to the casing.
    • There is a small black plastic spacer that goes between the bottom left screw and the logic board.
  33. Grasp the upper plastic casing where it locks into the internal frame and pull back. When the plastic tab has cleared the slot that the casing locks into, pull up enough to keep it from locking back into place.
    • Grasp the upper plastic casing where it locks into the internal frame and pull back. When the plastic tab has cleared the slot that the casing locks into, pull up enough to keep it from locking back into place.
  34. The PC card eject button on the laptop's left side prevents the upper casing from lifting up. In order to bypass the button, push it in far enough so that you can pull the upper casing's left side out and up beyond the button.
    • The PC card eject button on the laptop's left side prevents the upper casing from lifting up. In order to bypass the button, push it in far enough so that you can pull the upper casing's left side out and up beyond the button.
  35. Lift the left side of the case partly up so that you can access and disconnect the audio in/out cables from the sound card in the upper right of the case.
    • Lift the left side of the case partly up so that you can access and disconnect the audio in/out cables from the sound card in the upper right of the case.
    • Be careful not to lift the upper casing too far before you have disconnected the audio in/out cables or you may damage the sound card.
  36. Remove the upper casing. Note that there are two tabs on the laptop's front that often cause the upper case to stick.
    • Remove the upper casing. Note that there are two tabs on the laptop's front that often cause the upper case to stick.
  37. Your laptop should look approximately like this.
  38. Remove the two long silver Torx screws from the power card in the center of the laptop.
    • Remove the two long silver Torx screws from the power card in the center of the laptop.
    • Grasp the power card near the black plastic shield and lift up.
결론
다른 2명이 해당 안내서를 완성하였습니다.
첨부 문서
iRobot
회원 가입일: 2009년 09월 24일
1 평판
안내서 648개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 5,583
