주요 콘텐츠로 건너뛰기
PowerBook G3 Lombard Processor Replacement
필요한 것
  1. PowerBook G3 Lombard Processor Replacement, Keyboard: 1 단계, 이미지 1/1
    • Turn the computer so that the ports are facing you.
    • If the keyboard is locked, open the port cover and turn the keyboard locking screw until the keyboard is unlocked.
  2. PowerBook G3 Lombard Processor Replacement: 2 단계, 이미지 1/1
    • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
    • Make sure you have removed the laptop battery and CD/DVD module from the expansion bays before proceeding.
  3. PowerBook G3 Lombard Processor Replacement: 3 단계, 이미지 1/1
    • Lift the keyboard out by pulling it up and away from you. Rest the keyboard, face down, on top of the trackpad.
    • In order to replace the keyboard, you must first remove the modem.
  4. PowerBook G3 Lombard Processor Replacement, Heat Shield: 4 단계, 이미지 1/1
    • Remove the three silver Phillips screws that attach the heat shield to the internal metal framework.
  5. PowerBook G3 Lombard Processor Replacement: 5 단계, 이미지 1/1
    • Lift the heat shield up and pull it toward you.
  6. PowerBook G3 Lombard Processor Replacement: 6 단계, 이미지 1/1
    • Your laptop should look approximately like this.
  7. PowerBook G3 Lombard Processor Replacement, PRAM Battery: 7 단계, 이미지 1/1
    • Pull the battery cable directly up from the logic board.
  8. PowerBook G3 Lombard Processor Replacement: 8 단계, 이미지 1/1
    • Remove the battery from its holder by pulling up and to the left.
  9. PowerBook G3 Lombard Processor Replacement, Modem: 9 단계, 이미지 1/1
    • Remove the two silver Phillips screws from the modem.
  10. PowerBook G3 Lombard Processor Replacement: 10 단계, 이미지 1/1
    • Use a spudger, the tips of your fingers, or a flat non-metal tool to get under the modem's edge and pry it up from its socket as shown in the picture.
  11. PowerBook G3 Lombard Processor Replacement: 11 단계, 이미지 1/1
    • Disconnect the cable from the right side of the modem.
  12. PowerBook G3 Lombard Processor Replacement: 12 단계, 이미지 1/1
  13. PowerBook G3 Lombard Processor Replacement, Processor: 13 단계, 이미지 1/1
    • Use a spudger, the tips of your fingers, or a flat non-metal tool to pry up the processor's right side.
  14. PowerBook G3 Lombard Processor Replacement: 14 단계, 이미지 1/1
    • Disconnect the keyboard cable from the logic board by pulling directly up on the clear plastic loop.
    • This step is out of sequence with the keyboard because in order to remove the keyboard you must first remove the modem.
  15. PowerBook G3 Lombard Processor Replacement: 15 단계, 이미지 1/1
결론
다른 5명이 해당 안내서를 완성하였습니다.
첨부 문서
iRobot
회원 가입일: 09/24/09
1 평판
안내서 636개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 4
30일 전: 18
전체 시간: 5,845
