소개
This processor board also includes L2 cache. It is not soldered to the logic board, so installing a replacement is very easy.
Turn the computer so that the ports are facing you.
If the keyboard is locked, open the port cover and turn the keyboard locking screw until the keyboard is unlocked.
Remove the three silver Phillips screws that attach the heat shield to the internal metal framework.
Use a spudger, the tips of your fingers, or a flat non-metal tool to pry up the processor's right side.
다른 5명이 해당 안내서를 완성하였습니다.
