주요 콘텐츠로 건너뛰기
PowerBook G3 Wallstreet Fan Replacement
필요한 것
  1. PowerBook G3 Wallstreet Fan Replacement, Keyboard: 1 단계, 이미지 1개 중 1개
    • Remove both expansion bay modules using the levers on the front of the computer.
    • Insert your index fingers inside the expansion bays and search for the two ribbed tabs on the underside of the upper case. The tabs are located near the bottom corners of the keyboard.
    • Pull the tabs toward yourself and the keyboard will pop up.
  2. PowerBook G3 Wallstreet Fan Replacement: 2 단계, 이미지 1개 중 1개
    • Pull the keyboard forward to disengage the tabs holding it in back and rotate it toward you.
    • Rest the keyboard on the trackpad.
    • This is a diagram of the ribbon clamp connectors you will disconnect in the next step.
    • 1) With your fingernails, grasp the locking bar on either side and pull up a small amount (about 1/16" or 2 mm).
    • 2) After disengaging the locking bar, slide the cable out of the connector.
  3. PowerBook G3 Wallstreet Fan Replacement: 4 단계, 이미지 1개 중 1개
    • Disconnect the two keyboard connectors by disengaging the clamps and pulling the ribbons directly upward.
  4. PowerBook G3 Wallstreet Fan Replacement: 5 단계, 이미지 1개 중 1개
    • Slide a spudger downward between each plastic strain relief cable and the wall of the case in order to bow out the cable beyond the small tab holding it in place.
    • Once the strain relief cables are free, lift the keyboard off.
  5. PowerBook G3 Wallstreet Fan Replacement: 6 단계, 이미지 1개 중 1개
    • Your laptop should look approximately like this.
  6. PowerBook G3 Wallstreet Fan Replacement, Heat Shield: 7 단계, 이미지 1개 중 1개
    • Remove the two Phillips screws from the heat shield.
    • One screw is shorter than the other. When putting the Wallstreet back together, this screw goes in the middle of the heat shield.
  7. PowerBook G3 Wallstreet Fan Replacement: 8 단계, 이미지 1개 중 1개
    • Grasp the metal handle on the heat shield and pull up and toward yourself.
  8. PowerBook G3 Wallstreet Fan Replacement, Hard Drive: 9 단계, 이미지 1개 중 1개
    • Unscrew, but do not remove, the single Phillips screw from the hard drive bracket.
  9. PowerBook G3 Wallstreet Fan Replacement: 10 단계, 이미지 1개 중 1개
    • Grasp the hard drive bracket on the left side and pull up and to the left.
  10. PowerBook G3 Wallstreet Fan Replacement: 11 단계, 이미지 1개 중 1개
  11. PowerBook G3 Wallstreet Fan Replacement, Processor: 12 단계, 이미지 1개 중 1개
    • Use a spudger, the tips of your fingers, or a flat non-metal tool to pry up the processor's right side.
    • Remove the processor by sliding it up and to the right.
    • The processor and RAM can be removed as a unit. It is not necessary to remove the RAM from the processor.
    • There are two tabs on the left side of the processor that fit into slots on the metal framework. Make sure these tabs are in the slots.
  12. PowerBook G3 Wallstreet Fan Replacement, Modem: 13 단계, 이미지 1개 중 1개
    • Remove the single Phillips screw from the modem.
    • Disconnect the orange PMU cable by pulling it directly up.
  13. PowerBook G3 Wallstreet Fan Replacement: 14 단계, 이미지 1개 중 1개
    • Disconnect the modem from the logic board by lifting up on the right side using a spudger, the tip of your finger, or a flat non-metal tool.
    • Remove the modem by sliding it up and to the right.
  14. PowerBook G3 Wallstreet Fan Replacement: 15 단계, 이미지 1개 중 1개
  15. PowerBook G3 Wallstreet Fan Replacement, Clutch Cover: 16 단계, 이미지 1개 중 1개
    • Push the display back so that it lies flat.
    • Slip a spudger or your index finger under the clutch cover near the power button and pull upward until you feel it come free.
    • Repeat the previous step on the left side.
  16. PowerBook G3 Wallstreet Fan Replacement: 17 단계, 이미지 1개 중 1개
    • Lift the clutch cover off by rotating it up and then toward you.
  17. PowerBook G3 Wallstreet Fan Replacement, Display: 18 단계, 이미지 1개 중 1개
    • Disconnect the orange display data cable on the left side of the computer. Grasp the cable near the connector and pull directly up.
  18. PowerBook G3 Wallstreet Fan Replacement: 19 단계, 이미지 1개 중 1개
    • Disconnect the orange display inverter cable on the right side of the computer. Grasp the cable near the connector and pull directly up.
    • Make sure that both cables are free from the plastic casing before proceeding to the next step.
  19. PowerBook G3 Wallstreet Fan Replacement: 20 단계, 이미지 1개 중 1개
    • Turn the laptop around so that its back faces you.
    • Open the port door located at the back of the laptop.
    • Remove the four black T8 Torx screws.
  20. PowerBook G3 Wallstreet Fan Replacement: 21 단계, 이미지 1개 중 1개
    • Turn the laptop back around so that the screen faces you.
    • Adjust the display so that it is in a vertical position.
    • Hold the display on both sides and pull directly up until its hinges are free of their mounts
  21. PowerBook G3 Wallstreet Fan Replacement: 22 단계, 이미지 1개 중 1개
    • Your laptop should look like this.
  22. PowerBook G3 Wallstreet Fan Replacement, Upper Case: 23 단계, 이미지 1개 중 1개
    • Remove the four T8 Torx screws from the upper case.
  23. PowerBook G3 Wallstreet Fan Replacement: 24 단계, 이미지 1개 중 1개
    • Turn the laptop over.
    • Remove the eight T8 Torx screws from the bottom casing.
    • There are two longer screws in the front left and front right corners; make sure to put them back in the proper place when reassembling.
  24. PowerBook G3 Wallstreet Fan Replacement: 25 단계, 이미지 1개 중 1개
    • Disengage the small locking tab by pressing in on the upper case to the right of the PMU connector.
    • Lift the upper case up just enough so that the tab rests on its metal bracket.
  25. PowerBook G3 Wallstreet Fan Replacement: 26 단계, 이미지 1개 중 1개
    • Grasp the upper case near the back left corner and lift up partly so that you can access and disconnect the audio in/out cable from the sound card in the upper right corner of the case.
    • Be careful not to lift the upper casing too far before you have disconnected the audio in/out cable.
    • Remove the upper casing. Note that there are two tabs on the laptop's front that often cause the upper case to stick.
  26. PowerBook G3 Wallstreet Fan Replacement: 27 단계, 이미지 1개 중 1개
  27. PowerBook G3 Wallstreet Fan Replacement, Power Card: 28 단계, 이미지 1개 중 1개
    • Remove the single black T8 Torx screw from the power card.
    • Grasp the power card near the black plastic shield toward the center of the case and lift up.
    • Occasionally, a post connecting the power card to the logic board will come out with the power card.
    • Lift the sound card out by pulling up on both the right and left sides.
    • If the sound card sticks, pull the black metal wall of the casing toward you while lifting the right side of the sound card up.
    • Disconnect the fan connector from the logic board.
    • Remove the fan by pulling it directly up.
  28. PowerBook G3 Wallstreet Fan Replacement: 31 단계, 이미지 1개 중 1개
결론
다른 2명이 해당 안내서를 완성하였습니다.
첨부 문서
작성자
1다른 기여자 명과 함께
iRobot
회원 가입일: 09/24/09
1 평판
안내서 636개를 작성함
댓글 한 개
The second last picture (fan removing) is missing.
Thanks for your very good guides!
Willyatbooms Willyatboom - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 5
전체 시간: 4,313
