소개
Removing the heat shield enables access to the RAM and processor beneath.
도구
부품
Remove both expansion bay modules using the levers on the front of the computer.
Insert your index fingers inside the expansion bays and search for the two ribbed tabs on the underside of the upper case. The tabs are located near the bottom corners of the keyboard.
Pull the tabs toward yourself and the keyboard will pop up.
다른 한 분이 해당 안내서를 완성하였습니다.
